Performance and Tuning Discussion forum for various performance tuning techniques and questions
Memory saver?
Old Sep 23, 2015 | 11:45 AM
A82007's Avatar
Default Memory saver?
So I have a Schumacher memory saver. It says under the warning to insulate the battery Connector cables after I remove the battery to prevent them from touching each other or the chasis because it can cause a short.
The manual also says when* vehicle is turned off, to make sure your vehicle does not use more energy than the energy being supplied through the Schumacher memory saver. It says to go by the lowest fuse rating.* It says to measure the battery terminal with an amperage meter. And go by the vehicles book which should list the energy usage when the vehicle is off. I have an a8.
If you could give any suggestions as to what to use or how to insulate battery cables after battery is removed and whether this Schumacher me. Or saver will work on my vehicle or what book I need or how to look up energy consumption after vehicle is off.
iestatic
S4 (B8 Platform) Discussion
20
Jul 15, 2022 09:43 PM
flynavy
Q7 MK 1 Discussion
Sep 30, 2015 05:19 PM
ex-quattro PETE
Q5/SQ5 MKI (8R) Discussion
Sep 29, 2015 03:45 AM
Heidi Hixson
Sep 28, 2015 04:01 AM
userbbc
Sep 27, 2015 02:15 PM
