Mounting an electric fan in place of the belt driven fan (more)
Any thoughts on how it should be done? The fan I bought (12" - Mr Gasket) comes with the plastic strips that go through the radiator. In order to do that, I'd probably have to separate the condensor to get them in. Or should I try to mount the fan to the shroud with some brackets?
TIA
TIA
Re: Mounting an electric fan...electrical "tie-in" info.
Not sure how electric fans are configured on the Audi A8 (possibly A6 also); but you might want to duplicate that configuration for sake of reliability.
$0.02
$0.02
The A4 already has a secondary fan that is triggered by a temp sensor...
I was just going to wire the new fan up to that, so they both turn on when the temp switch tells them to.
Re: The A4 already has a secondary fan that is triggered by a temp sensor...
Secondary fan is for engine cooling also. The secondary fan has two speeds that will kick in if belt driven fan in not enough. That temp switch is a bit high in degrees to rely on for cooling though. You can get a low temp fan switch from Neuspeed. It is that same one the Audi's and VW's have been using for years and just kicks in at lower temps. A better but more expensive solution is to use the PSM unit I choose. With it have it keep on/turn on the fans until underhood temps get below a certain level. The passenger side fan blows right across the turbo/exhaust manifold and this has worked out great instead of a turbo timer.
www.PSM1.com
www.PSM1.com
Whoa!
>of a turbo timer.
No amount of air cooling is going to keep oil from "coking" on red-hot turbo bearings if you shut the car off while the turbo is still hot.
--Dan
Mach V
>of a turbo timer.
--Dan
Mach V
Wiring in parallel draws more current,...
...if A6/A8 is like this, fine. You should be OK.
If each fan has separate relays (on A6/A8), you should consider doing it this way, even if it's a little extra work.
