Performance and Tuning Discussion forum for various performance tuning techniques and questions
My first A6
Old Aug 2, 2003 | 12:18 AM
kimball's Avatar
New Member
Default My first A6
I just purchased a 99 A6 2.8Q. I am looking to do some performance upgrades, but unfortunately i am running into some trouble. I have already been told about chips and super chargers, but isn't there anything else avaliable? Doesn't the VW VR6 have the same engine? If so, are the aftermarket mods interchangeable?
thanks for all your help.
Old Aug 2, 2003 | 06:51 AM
cuatrokoop's Avatar
Default Re: My first A6
VR6 = 15d Vee, very large single cylinder head for all 6 cylinders, 12v or 24v
V6 = 60/90d vee (can't remember which), two cylinder heads, 12v or 30v.
Basically nothing interchanges between the two.
Go with a PES supercharger if you want the most from your 30v, IMO. Its what I would do.
Old Aug 2, 2003 | 06:21 PM
kimball's Avatar
New Member
thanks
Old Aug 3, 2003 | 03:40 PM
fastdream's Avatar
Junior Member
Default there are other things
you can do.
What is it about the supercharger route that turns you off? Money? If so I'm afraid it is one of the cheapest ways to get a decent upgrade of reliable power.
You could theoretically go with nitrous. I wouldn't.
Of course you can spend some bucks and have the engine "built" or reworked internally with some goodies for more power normally aspirated(na). But that will likely make it a little less driveable in day to day routine useage (a "built" engine is usually more race oriented, so your power band will be stronger in the higher rpm range)
plus that will likely be as expensive or more expensive than just bolting on a supercharger kit. I'm sure you could just do a few things like cams, ECU, exhaust and get a decent power upgrade.
If you're interested in the built na route, see the link to read about an A4 with the 3.0 V6, similar if not the same as your engine.
You could always go nuts and swap in a 2.7t and then you can have a lot more fun...
or do the hpamotorsports swap, twin turbo vr6...major cabbage for that one though.
You could build your own turbo setup as well...but that requires a lot of knowledge on your part or an expensive performance shop to provide that, besides which I haven't yet read of anyone doing that with the 2.8.
Good luck. Your only limit to power is your budget<ul><li><a href="http://www.northtexasaudigroup.com/forums/showthread.php?s=f4264a91c08ca69845d0c1879e000f65& amp;threadid=4290">http://www.northtexasaudigroup.com/forums/showthread.php?s=f4264a91c08ca69845d0c1879e000f65& amp;threadid=4290</a</li></ul>
Ow-De Aye Sicks
Aug 2, 2007 03:05 AM
cculos
Mar 29, 2004 02:44 PM
speed limit?
15
Jan 12, 2004 09:37 AM
Mark P
Feb 11, 2002 07:09 AM
Johnaton
Misc. Models Discussion
Dec 30, 1999 08:44 AM
