Performance and Tuning Discussion forum for various performance tuning techniques and questions
Ok...need some solid reasoning on BPV orientation...
Old Feb 7, 2003 | 01:52 AM
  #11
Digit@lex's Avatar
AudiWorld Expert
Default Thanks again. I read that in your past thread about the delay.
What valve are you using with your FMIC? BTW, thanks again for the clarification. Good stuff to know.
Old Feb 7, 2003 | 07:00 AM
  #12
WYSIWYG's Avatar
firkin more techno-babble wont get you guys anywhere - whichever works damnit!
Old Feb 7, 2003 | 07:06 AM
  #13
Digit@lex's Avatar
AudiWorld Expert
Default They both do! That's the problem. :-)
But I will do it the WYSIWYG way. Try one way and do some runs...and then try the other way and do some runs. The better numbers win. :-)
Old Feb 7, 2003 | 07:22 AM
  #14
Audi2ptzero's Avatar
Elder Member
Default Back pressure?
The valve will always have pressure on one side and vacume on the other caused by the turbo since the turbo is doing all the work. The vac line will have either vac or pressure depending on the state of the manifold.
BTW if you switch the way the BPV is you just change which side the pressure/vac is on the valve.
Old Feb 7, 2003 | 07:24 AM
  #15
Elder Member
Default Well I had 3 different stock valves in but they were all bad.
2 of my good friends had a spare 110 porsche valve laying around, so I installed it at the drags and it has been holding great so far on the 2 liter K04 setup I have.
Old Feb 7, 2003 | 07:39 AM
  #16
WYSIWYG's Avatar
head to ATCO when the snow stops
Old Feb 7, 2003 | 09:40 AM
  #17
Digit@lex's Avatar
AudiWorld Expert
Default Where's ATCO? My clutch is slipping now... :-(
Time to upgrade! :-)
Old Feb 7, 2003 | 11:08 AM
  #18
PKBlu::E30 Hunt's Avatar
Default Just spoke with Stratmosphere and APR regarding this
both said they had either never heard of changing the orientation of the DV or they didn't recommend it. Where are you guys getting this information from?
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 7, 2003 | 01:27 PM
  #19
WYSIWYG's Avatar
youre on your own with that one =) atco is in berlin, NJ (atcorace.com)
Old Feb 7, 2003 | 02:45 PM
  #20
Digit@lex's Avatar
AudiWorld Expert
Default Hehehe, knowing what it takes is something I'll let some other people handle.
I still owe you for the install help. I haven't forgotten...I'm working on the ladies for you. 8-)
Beater
Apr 6, 2006 09:43 AM
RussB
11
Mar 2, 2006 03:29 PM
auditunerb5
Mar 13, 2003 02:41 PM
JKim1.8T
Mar 13, 2003 08:06 AM
Hawaiiannights
Mar 11, 2002 03:41 PM
