Overboost or no?
Any help?
Any help?
Boost is just a measure of air pressure, you need proper amount of fuel and advanced timing to max power. So boost by itself does not mean you will make big power. All the other parts of the system must be working optimally.
In this situation you would want to .......
1. Log - fuel, boost and, timing
2. Insure your fuel filter has been properly serviced
3. Insure your air filter has been properly serviced
4. Pull the plugs and at least insure the gap is proper .032"
When you log boost you will find out if you maybe have a mild tune installed.
Logging is done by running the car in 4th gear from 2500 rpm to redline.
Once all of this has been done, you are likely to discover most of the issues or at least have an idea where the issue are.
