Performance and Tuning Discussion forum for various performance tuning techniques and questions
Performance Built K03
Old Oct 17, 2001 | 12:02 PM
Rob S in PA's Avatar
New Member
Default Performance Built K03
Hey all..
Seeing all the talk about modified K04s, has there been any research / work done to modifying a K03? Things to make it more efficient like different bearings or blade arrangement?
Is there a link to any info on the different turbos available for the A4 (like all the cool mod'ed K04s)??
Old Oct 17, 2001 | 10:21 PM
CMH's Avatar
CMH
Senior Member
Default Why would you need to do that to a K03. That would be a waste of money.
I run a stock K03 with a custom chip.
Old Oct 18, 2001 | 09:32 AM
Dr. Mike's Avatar
New Member
Default TAP tried this, and if you search the archives you can see the results.
Hello,
Just check the archives under "K03 Sport" and you will see the problems in this. If you aren't happy with a turbo, (IMHO) buy a different turbo, it is cheaper than modifying an existing one, and a great deal more reliable.
There is no inherent problem with the K03 (just look at cmh), it is just small, period, but that is what makes it "feel" like a small V6 in that there is little-to-no lag (instant response) and most of the boost in the factory ECU program is below 4000rpm (where you do most of your driving).
Just my $0.02,
Michael
addìct
27
Aug 6, 2003 12:37 AM
s54m3
Oct 12, 2002 06:47 PM
dbman96
Feb 13, 2002 04:57 AM
kam1200
Aug 15, 2001 03:48 PM
