Performance and Tuning Discussion forum for various performance tuning techniques and questions
PLEASE HELP!
Old Oct 24, 2002 | 10:29 AM
powerbook76's Avatar
New Member
Default PLEASE HELP!
recently i've had problems where the check engine light lit up. brought it to the dealer, they said the problem was the GIAC Chip.. brought it to place i installed the chip, remove the chip, they said the problem was with audi not the chip. brought it BACK to the dealer, the problem is STILL with the chip that USED to be in there.
is that a possbility? could it be b/c of GIAC?
i recently also installed GFB BOV.. could THAT be problem? i heard BOV tends to make 2001 a4 run "rich" could that cause engine light to light up? PLEASE HELP!
Old Oct 24, 2002 | 11:18 AM
®ob's Avatar
Default It's not the chip...its a classic case of laziness at the dealer
Get a VAG-COM and check the codes yourself. I'd also remove that BOV. Replace it with a BPV
Old Oct 24, 2002 | 11:23 AM
4kq's Avatar
4kq
Member
Remove the $#%# blowoff valve.
Old Oct 24, 2002 | 02:46 PM
CharlieGSanD's Avatar
Senior Member
its the BOV
Old Oct 24, 2002 | 04:15 PM
Lucas_Gchips's Avatar
Default What Year is Your car.
If it is Non BDW either the GFB Bypass or Hybrid valve should work.
I have GFB Hrbrid in My car for a month now now probs or DTC.
If its a DBW stick with the GFB Bypass, Hybrid valve not recomeneded, but may work.
In any Case Have you got the revised Spring from GFB.
If its a BOV only, then yes take it off and get Bypass or Hybrid.
Pure BOV is not suited to stock or chipped car.
Old Oct 27, 2002 | 06:11 AM
Singletrack's Avatar
Default Ask the dealer for the specific code, he should be able to give you that much at least.
Then someone here can give you an educated guess and what the cause might be. It could be related to your setup, or it could be something totally unrelated.
-st
Old Oct 28, 2002 | 05:06 AM
johnAWD's Avatar
New Member
Default Re: PLEASE HELP!
If your new BOV is venting to atmosphere, route the outlet back into the intake between the MAF and the turbo. Venting pre-metered air is a bad idea, unless you've done a MAF to speed density conversion since there is no metering of the air, but rather a computation based on manifold pressure, RPM, TPS...
TTturbine
16
Mar 18, 2018 04:21 PM
ultrasport1.8t
Apr 22, 2006 09:27 AM
4s4s
Jul 26, 2003 09:38 AM
powerbook76
Oct 24, 2002 10:43 AM
1.8docA4
Jun 13, 2002 05:26 AM
