Problems with Newly instaled GIAC Chip !! ??
Got a VAG-COM?
check the long term fuel trim on block 032, and also watch the short term FT on block 033.
Spec for LTFT is +/- 10%, but ideally it should be as close to 0 as possibly. STFT should oscillate within +/- 10%. If under part throttle acceleration, you see it go over 10%, then you might have a hole in the fuel map. Negative % means rich, positive % means lean.
Also check your BPV. I have a Forge BPV, and it will flutter a little on low-boost acceleration.
zeus1
03-17-2005 08:51 PM
rick5ktq
09-24-2004 03:23 PM
dohc
08-23-2002 08:36 PM
