Problems... Problems....
I can't honestly say how good, since I have a known MAF problem. Hopefully by next weekend I'll have that taken care of, so I can give a better report on the chip and how it's running.
The problem was, the air was coming in perpendicular to the MAF at high speeds (70-80mph) and just throwing the readings off.
From what I've heard, you need at least 6" of straight pipe before and after the MAF. If you don't, then you can get bad readings. I don't have enough room for another 12" of pipe there, so I have to move my MAF
A couple things to check are the Fuel pressure and a compression test (if all the air is leaking past the rings, it could run rich)
Another possibility is a leaking injector, but that would cause it to be rich at idle, which it's not (1st field in block 032)
Try cleaning the MAF, resetting the ECU, adapting the throttle, and check the coolant and air temp sensors to make sure they are reading right (via the VAG-COM)
It could also be a bad O2 sensor. Over time they can degrade, especially if they're running really rich.
Also try blocking the filter. Have you rotated the MAF recently? The elbow behind it could cause bad readings depending on the housing rotation. It's probably not enough to cause a 20+% change though.
Like a shoebox without the lid with the opening turned towards the front of the car.
DBW does not use the 02 at wot, it does use the maf readings to help set the injector pulse. So that means it is running on the set fuel maps but with an adjustment from the maf.
Mau's car was running fine up on the same chip. It then started to run rich and he is just trying to figure out why. Both of his fuel trims have changed alot since it used to run good. His STFT should be around -5% and LTFT whould be around -15%, but as you can seen STFT has gone lean and LFTF has gone rich. It is just hard to acutally stay out of boost on a dbw since boost is set on motor and pedal loads with the dbw setup.
BTW john, when does a turbo car make boost? Would that be only when your on the throttle or would it actually be all the time? I am pretty sure that boost is made even when driving at part throttle. If there is a slight leak after the turbo which will have pressure between the turbo and throttle body, then the leak will let some pressure/air out before it gets to the motor and then the car will run rich since that air that is leaked out was counted by the maf.
