Performance and Tuning Discussion forum for various performance tuning techniques and questions
Reducing compression
Old Sep 23, 2003 | 07:37 PM
JeffinMd's Avatar
Default Reducing compression
I must be missing something. I've heard people
talk about "spacers" betwen the head and block to reduce the c/r (I'm not saying this is a good idea).
However, I've never seen anyone talking about moving the opposite direction.
Is there room to shorten the piston connecting arms to increase the combustion volume as well? Is there a simple reason why this is a really bad idea?
Thanks, Jeff.
Old Sep 23, 2003 | 08:33 PM
Audi2ptzero's Avatar
Elder Member
If you shorten the rod, the piston top is not going to reach the top of the block.
Old Sep 23, 2003 | 11:39 PM
Lucas_Gchips's Avatar
Default Re: Reducing compression
You can also fly-cut pistons tops to reduce compression.
Old Sep 24, 2003 | 04:16 AM
WYSIWYG's Avatar
Default *homer simpson voice* in theory, you can raise the sparkplugs... in theory
just kidding
Old Sep 24, 2003 | 06:16 AM
JeffinMd's Avatar
Right! But wouldn't that "look" the same as having the spacer above the piston top?
Old Sep 24, 2003 | 11:35 AM
Toaster29's Avatar
Default Not really...headspacers tend to screw up the carefully designed quench zones designed...
by the factory.
Old Sep 24, 2003 | 12:53 PM
xr4tic's Avatar
Default Why mess with the rods, when you can just change pistons?
Shorten a rod, and you also make the piston go further down the cylinder, possibly going too far, or hitting the crank.
Plus, these rods would have to be custom made.
It's easier to just have a set of dished pistons made to your specs.
Old Sep 24, 2003 | 12:59 PM
cuatrokoop's Avatar
Default Also, a shorter rod will screw up the "rod ratio", which IMU is a motion ratio
It'll also screw up the balance of the whole assembly (Crank + rods + pistons). That's easy to take care of by any competent machine shop, the ratio difference isn't.
New lower CR pistons are the ideal way to drop static CR. Cam timing can drop dynamic CR.
 Michael S. Palmer
Old Sep 24, 2003 | 05:52 PM
squidix9's Avatar
No Bozos!
Default Head spacers also
screw up the valve timing.
Last time my head was milled, I added back that amount to the headgasket to make up the difference.
Old Sep 24, 2003 | 07:35 PM
sw20T's Avatar
New Member
Re: yup, don't mess with the rods, just alter the piston dish volume
VONBOTTLE
Apr 12, 2011 03:33 PM
BluHeaven
Jun 6, 2008 09:34 PM
Pop3
11
Sep 22, 2006 07:32 AM
NogaroGO!
Dec 11, 2004 03:47 PM
rabbid
May 14, 2003 06:18 AM
