Performance and Tuning Discussion forum for various performance tuning techniques and questions
Replacement fuel pump
Old May 13, 2003 | 12:40 AM
Two Tees's Avatar
New Member
Default Replacement fuel pump
hi all, just upgraded to bigger turbo, added secondary injectors, running standard boost and planning to boost it up. Is there any direct replacement from Bosch for the fuel pump for the TT to support the additional fuel needs? (like for a stage3+ catering pump?)
Or any suggestions of alternatives or experiences would be appreciated.
thanks!
Old May 13, 2003 | 08:56 AM
Audi2ptzero's Avatar
Elder Member
Default I think the only real replacement is a Walbro 255 gph pump.
Hope I that is right.
Old May 13, 2003 | 06:19 PM
gesTTalt's Avatar
Default What turbo have you uprated to? Why did you go secondary injectors instead of
swapping out to just larger injectors? Have any pics of your new set up?
Old May 13, 2003 | 06:23 PM
Elder Member
Default Most likely running a piggy back ECU
to control the second set of injectors. This way the second set does not come on till after boost hits.
Old May 13, 2003 | 06:30 PM
gesTTalt's Avatar
Default Something like a Blitz controller? I see that you're running a custom turbo,
is it a hybrid of some sort?
Old May 13, 2003 | 10:21 PM
xr4tic's Avatar
Default If it's like the A4...
then a RS4 pump is an option ($$$$, but still an option)
I have a Walbro 255lph in my A4, it's not a straight drop-in, but it's really not all that hard to do.<ul><li><a href="https://forums.audiworld.com/performance/msgs/44541.phtml">https://forums.audiworld.com/performance/msgs/44541.phtml</a></li></ul>
Old May 13, 2003 | 10:22 PM
Elder Member
Default It is a AirWerks turbo which I got thru Innovative Turbo.
Took about 2 months to spec just for the application we were looking for since I know have a 2 liter motor in my A4.
Old May 15, 2003 | 05:55 PM
Two Tees's Avatar
New Member
Default Re: If it's like the A4...
Mine's a TTq 225, upgraded to a GT25 hybrid still running standard boost, but worry the stock pump cannot make it at high boost.
So in line it should be then, thanks all..
 Michael S. Palmer
audidrvr
Audi Original "S" Cars
13
Dec 31, 2007 07:57 AM
ISRAEL-TT
Jan 3, 2004 12:42 AM
Pearly
Dec 17, 2003 11:42 AM
Shaun@SG
Mar 20, 2003 05:41 AM
BigMouse
Aug 21, 2002 06:13 AM
