Performance and Tuning Discussion forum for various performance tuning techniques and questions
Seat bracket question?
Old Jun 23, 2001 | 10:39 AM
A3 Landstuhl DE's Avatar
New Member
Default Seat bracket question?
I want to replace the stock seats so....
Does anybody know of a tuner that makes seat bracket, and a plug to defeat the airbag on a 2000 S4?
On a side note my seat with out the heating element weight in at 58.5 pounds each.
Me on the scale 148.0 pounds;
Me on the scale, plus the seat a stout 206.5 pounds.
Thank you.
Old Jun 23, 2001 | 09:24 PM
achoy22's Avatar
New Member
Default Re: Seat bracket question?
Depends on which aftermarket seat you've got. I have recaro SPG race seat for my S4 right now and I have custom make bracket. However, I also have a orginal recaro seat bracket for sell right now. And the airbag light will comes on if you remove the stock seat.
Old Jun 25, 2001 | 05:24 AM
Shortbus S4's Avatar
Default plug solution, maybe
I'm in the same boat. I've got a set of Recaros from a Jetta GLi and need to get a Recaro brackets. Someone last year mentioned about putting a 5ohm resistor and that would turn off the light-- I have not tried this yet...I'm worried I'll kickoff all the airbags or something stupid.
I found a wrecked 2000 A4 with sport seats, I am hoping to get to the salvage yard that has it. Then I am hoping that the plug is similar to the S4. If so, I may try to make a plug from the A4 harness and hopefully that will keep the light off.
Once I get around to it all and make it work I'll definately post the info.
Chris
'01 Imola Avant w/Tip
Old Jun 25, 2001 | 09:12 AM
Sharon's Avatar
Senior Member
Default depends on the seat
I've got Sparco Evo seats. Sparco sells a bracket to mount to a non-power seat Audi (e.g., A4 w/o power seats), which I use and had a shop weld the proper attachment on.
BTW, my stock S4 seats were 65lbs each.
Yes, I have an airbag warning light on. Like Shortbus says below, you should be able to put a resistor in there, but I haven't tried.
Old Jun 25, 2001 | 09:16 PM
New Member
Thanks for the info all, I will check and see what the S4 group has to say.
Kenny Lin
Feb 19, 2014 09:49 AM
kvanwagoner
A4 (B7 Platform) Discussion
16
Feb 10, 2006 01:38 PM
gte678n
Feb 12, 2005 07:48 PM
mpm
Audi allroad
Jan 25, 2002 08:52 PM
gpgnat
Oct 24, 2001 07:02 PM
