Spark Plug recommendations?
This is the one that got me thinking: <a href="https://forums.audiworld.com/a4gen2/msgs/263262.phtml">https://forums.audiworld.com/a4gen2/msgs/263262.phtml</a>
Right now, I'm running the stock Bosch 3-prong plugs. I prefer these over the gee-whiz platinum and iridium plugs since they're cheaper (~$4 each), work just as well, and I don't feel bad when I foul a set out when running super-rich
The question is, now that I have a bigger motor and turbo, should I start running a colder plug?
The NGK website recommends one range colder for every 75-100hp increase over stock.
Jeff (from the link) recommends NGK BKR6E or BKR7E (aka 6097 - one heat range cooler)
The NGK BKR7E/6097 seems to be popular with the Supra guys (but I don't have a Supra motor)
Are there any better copper plugs out there?
The multi-prong plugs might last longer, but I'm thinking a single prong plug would be easier to experiment with gap, so I'm thinking that's the direction I want to take.
My XR4Ti runs $1 Autolite plugs, and they work great, just need to be changed every 5k or so, so I have no problem swapping plugs out earlier than the factory 30k recommendation.
What are you big turbo guys running? Stock?
I mentioned this here once before, but just to add confirmation to coppers as the plug of choice. I know place that dyno'd a half dozen plugs. The NGK copper plug dyno'd 6hp higher than any other plug, it was the only copper one they tested in the group.
RCY9 somthing or other. so far, REALLY happy (couple hundred miles on em)...the iridiums (IK22) were fouling non-stop as were the bosch plats that APR sends and recommends. Cleaning them didn't help this last time. Kenne Bell always advised me to run copper plugs on the s/c kit I bought from him..."better conductor, just replace em every 10K"
so I'll watch these carefully and see how they do. Smoother accel. and better idle so far.
Theoretically, increasing the boost is the same as raising the compression, your cylinder pressure will go up. This is what causes the extra heat, not to mention the fact that the turbo air is pretty hot to start with.
My interpretation is it goes three ways:
1. compression increase
2. adding a turbo/supercharger
3. increasing boost
