Spark Plug recommendations?
Mike O.
It's most probable that copper, with the fatter electrode can sink in more heat than the platinum or irridium counter parts. But increasing the gap from what the stock ones are set up, can mean a rash of burnt coil packs. Stock coil packs can only produce so much voltage. If they are required to produce more, they will overheat, could break, but at least before that, misfire usually starts to happen - oh so slowly though, so one better be vagging while he plays with spark - or just replace it with higher energy coil packs and gap away!
I'd like to see a reference showing 70% difference in energy to jump the same gap on a plat vs. copper plug. I'd expect the opposite qualitatively, tho' not sure at that magnitude of difference.
(not arguing with you...just trying to learn more here)
i may be rethinking again. the problem for us big rich running turbo kit guys is this:
I have run the plats that apr sent and iridium IK22 (all one range cooler). That's probably safest when you're in the boost pretty hard, but for daily driving, they foul and they foul quick. i haven't discovered a way to get them to self clean easily.
These copper plugs don't look like the answer either, now. At the same heat range, I'll likely have the exact same issue shortly.
thinking out loud, I'd say it would be great to run stock heat range for daily use and swap to cooler plugs for the track to prevent fouling. The danger would be preignition if you had a spirited run on the hotter plugs.
thoughts?<ul><li><a href="http://home.att.net/~t.vago/faq-ignition.html">copper vs. platinum</a></li></ul>
I took a quick look at the chart, and without reading the whole document, I'm trying to figure out - how did he measure that? I hope it's not from a electronics multi meter that only puts out millivolts to about 3 volts depending on the range selected. If so, let me ROFL first. If not, I'm curious how he measured resistance if he has to supply thousands of volts and divide by whatever current is required to form the arc. I'll go try to find some read on their difference. It was something I did some searching a while back.
Its amazing what you can get people to trade you when you do work for them (he did some ECE work for a guy who had that stuff, its worth a few thousand dollars on the low end...).
Aloha,
Keoni
