Performance and Tuning Discussion forum for various performance tuning techniques and questions
Split Second Boost Controller
Old Jun 22, 2001 | 07:44 PM
Usher's Avatar
New Member
Default Split Second Boost Controller
Anyone have the Split Second Boost controller instead of a chip. Any comparisons, advantages, disadvantages. I have a 2001 Avant and am planing on installing either the Split Second or the APR chip...
Old Jun 22, 2001 | 10:30 PM
Pat-SoCal's Avatar
Default Split Second? I think you mean fuzzy logic.
Could you please clarify if you have an A4, A6, or S4? Is your car "fly by wire"?
Old Jun 23, 2001 | 04:31 AM
Usher's Avatar
New Member
Default Re: Split Second? I think you mean fuzzy logic.
Sorry, It's an A4 1.8. The Split Second box is is written up in the May Europen Car Tech files section. Essentially it's an electronic adjustable boost box that goes from stock up to 14.5 psi of boost and has an LED readout. It just wires in to the harness off the ECU and cost $299. Seems like a nice set-up. They don't have it for the 2.7 as far as I can tell from their website. (www.Splitsec.com)
Old Jun 23, 2001 | 09:33 AM
Bollinger's Avatar
Elder Member
Default always use an ECU mod instead of a separate boost controller when possible
The boost controllers work by fooling the ECU. If they fool the ECU, the ECU cannot control parameters accurately because it doesn't really know what is going on.
Old Jun 23, 2001 | 11:45 AM
WYSIWYG's Avatar
well, you only adjust the boost, but it still uses the oem fuel mapping (and others)
Old Jun 23, 2001 | 12:44 PM
Pat-SoCal's Avatar
Default Try to understand boost is important, but only part of the end result.
The aftermarket chips control timing (to build boost at low rpm) as well as the a/f map (nevermind the a/f map for now). Sure you can throw a boost controller on and turn the wic up, but you won't be accomplishing what a chip can (safety of retarded timing at full boost). The chip holds the key to unlocking these cars potential, and they do it through the timing. We already established the chip's roll in adding timing to build boost faster at lower rpm, but as boost falls off at higher rpm, the chip compensates by adding additional timing. Can your boost controller do that?
Old Jun 27, 2001 | 12:47 PM
Sal R.'s Avatar
Default A fellow A4 owner...
...rbarna, I think, rigged one up on his 2001.5 1.8T. However, there have been discrepancies in his findings and use of the SS BCS. He reported that his stock boost levels, read through the BCS, as 7psi when stock for the 01 is 10-11 psi. He didn't have a boost gauge to confirm and I haven't heard since what's up.
94LSC
Audi Original "S" Cars
16
May 26, 2021 10:49 PM
Krissrock
10
Aug 24, 2007 05:36 AM
quattroson1
Apr 29, 2003 07:08 PM
I AM 2ks4
Apr 3, 2003 02:58 PM
vt01s4
24
Jan 19, 2003 06:39 PM
