Performance and Tuning Discussion forum for various performance tuning techniques and questions
Is a Split Second PSC1 needed on a K03 w/...
Old Apr 28, 2003 | 03:58 PM
(not a) $leeperA4's Avatar
Junior Member
Default Is a Split Second PSC1 needed on a K03 w/...
APR chiping, Evo Intake, N75, exhaust, and soon to be DEI Co2 kit? Would I sleep better with it? Most likely going to get a K04 and Z-flow FMIC.
Old Apr 28, 2003 | 08:54 PM
xr4tic's Avatar
Default Nope....
in fact, I wouldn't even bother with it in your case. If you find you're running a little rich, or lean in some places, then it might be an option, but the K04 kits are pretty well tuned right out of the box.
Old Apr 29, 2003 | 07:37 AM
Junior Member
Default Re: Nope...
It almost seems that I am running a bit rich now, accroding to my A/F guage, I know the car will run rich at WOT, but it seems like after 50% throttle it runs on the first/sencond bar of rich. (autometer A/F) As you get to 75% throttle, i am 1/4 into the rich, WOT I am into 3/4 rich. Is this normal?
Old Apr 29, 2003 | 07:55 AM
Angry Alex's Avatar
Default seeing your sig always stirs up the momories...sigh....
<center><img src="http://pictureposter.audiworld.com/22856/dscn0758.jpg"></center><p>
Old Apr 29, 2003 | 08:26 AM
cuatrokoop's Avatar
Default Re: Nope...
Those AF gauges are not all that great. Its a generalization really, since most factory O2's don't have the resolution to give an accurate description of what is going on. You need a wide band O2 ($$$) or just go with an EGT probe + gauge to get a better picture of what is going on as far as rich/lean conditions.
And from what I've seen, most chips tend to run a little rich since it is safer for the end users (no one engine will run exactly the same, so err on the rich side of things)...
bhvrdr
27
May 4, 2005 04:54 PM
box_of_partS4
16
Aug 7, 2004 11:00 AM
Chuck-S4
22
Sep 16, 2003 08:54 AM
kenny (dremel)
Apr 16, 2003 02:35 PM
AudiAddict B7
Feb 20, 2003 04:13 PM
