Performance and Tuning Discussion forum for various performance tuning techniques and questions
stasis solid motor mounts
Old Feb 20, 2005 | 05:37 PM
auditunerb5's Avatar
Default stasis solid motor mounts
What's the story with the stasis solid motor mounts. What would these be like for the street? Is s4 mounts the only other alternative? How bout rs4?
Old Feb 20, 2005 | 06:48 PM
Yippers®'s Avatar
Member
Default Just missed ?? a GB for the RS4 mounts thru Mike @ Pure MS .. maybe give him a holler and see?
Failing that, ECS has them for a couple $ more. The deal with Mike was mostly free shipping...
Old Feb 21, 2005 | 05:01 AM
Audi2ptzero's Avatar
Elder Member
Default 2.7/2.8 mounts should be good enough.
If you go too stiff you will increase the knock sensor readings which will also increase timing being pulled back.
Old Feb 21, 2005 | 09:47 AM
Yippers®'s Avatar
Member
Default From my reading on the S4 forum .. the knock sensor voltage will go up. Folks do not seem to see
any increase in timing pull back from using stiffer mounts.
Old Feb 21, 2005 | 10:23 AM
Elder Member
Default If the knock sensor readings hit their limits because of the stiffer mounts
then the timing being pulled will increase. The key is to make sure you keep them down as much as you can with either motor mount. Wont gain anything from a mount that is too stiff for the setup.
Old Feb 21, 2005 | 03:35 PM
Yippers®'s Avatar
Member
Default Of course if the limits are reached you'll have issues but that doesn't seem to be an issue with the
stiffer mounts. All the data I've seen show increased volatage but no (more than with the prior set up) timing pull.
Old Feb 22, 2005 | 06:32 AM
Ray Khan's Avatar
Default those cars make a ton of tq, wouldn't they be more apt to have problems
with the stiffer mounts than us? Or does it have more to do with the tq to engine weight ratio?
Old Feb 22, 2005 | 07:24 PM
Yippers®'s Avatar
Member
Default I'd imagine the heavier V6 and the heavier V6 torque would benefit more from the stiffer mounts than
our little 1.8s would.
Solid mounts might well cause timing pull but with the hydrualic mounts I think the higher torque Stage 3's would benefit .. help with the driveline flopping around. I think it's worth a shot to try 'em ...
 Michael S. Palmer
Old Feb 22, 2005 | 11:17 PM
Devious27t's Avatar
Member
he has a stand alone. the ecu will not pull his timing.
Old Feb 23, 2005 | 04:03 AM
Default Yea I wont be having any timing pull problems, just wondering
about super harsh vibrations from the solid mounts? I should be well over 300lb of tq.
