Performance and Tuning Discussion forum for various performance tuning techniques and questions
Stoptech pad bedding procedure question.
Old Sep 16, 2002 | 05:07 PM
S4inSoFla's Avatar
Member
Default Stoptech pad bedding procedure question.
I've got Stoptech and I have been running Pagid Blue pads. I installed Orange pads for a track event this weekend and was bedding them in tonite. I am doing what Matt@Stoptech recommended, 10 stops from 60-5mph using 70% effort, then 4 stops from 80-5. After the tenth 60-5mph stop I heard a loud rubbing sound coming from somewhere in the front, it was obviously the brakes. I stopped driving it hard and went home, gradually the noise went away.
Is this normal? I'm thinking I didn't damage anything since the sound went away and there never was any vibration. Thanks for any advice.
Old Sep 17, 2002 | 12:25 AM
Carol from Canada's Avatar
Default Was more of a metal-on-metal rubbing noise?
I had the same noise while bedding in Porterfields. It also happened a few more times during the first two weeks.
I believe the caliper was not retracting properly due to brake dust on the caliper guides. The outer pad would stick to the rotor and cause an awful rubbing/grinding noise.
Old Sep 17, 2002 | 11:39 AM
S4inSoFla's Avatar
Member
Did it go away or did you have to reinstall the pads?
Old Sep 17, 2002 | 09:13 PM
Default It went away by itself after a few days.
If it doesn't I suggest greasing the caliper guides.
dany0212
Nov 14, 2008 02:08 PM
sidespar
Aug 29, 2007 04:24 AM
JoBuNY
Feb 28, 2007 06:31 AM
S4inSoFla
Sep 16, 2002 05:24 PM
WarrenY
Dec 20, 1999 04:23 PM
