Are thaere any reasons we can't use these crankshafts to stroke our engines?
I'm not sure if there is a difference in cylinder spacing or it might screw up the compression but I was just curious if these crankshafts would work on a 1.8t.
Steven H<ul><li><a href="http://www.eiptuning.com/enginesandparts/cranks.html">VW 4 cylinder crankshafts</a></li></ul>
Re: Are there any reasons we can't use these crankshafts to stroke our engines?
Spacing for rod/main bearings (as well as bearing journal diameters) are likely the same for these crankshafts as for the 1.8T crankshaft.
Differences (I believe) are in the configuration at the front and back of the crankshaft where pulleys and flywheel bolt on (diff. bolt pattern).
inliner311
9
12-17-2006 12:01 PM
kday
Audi Original "S" Cars
14
09-27-2006 04:10 PM
OldManTan
02-16-2006 04:47 PM
