Performance and Tuning Discussion forum for various performance tuning techniques and questions
Theoretical top speed of B6 A4 Quattro fitted with a 6 speed gear box?
Old 12-28-2006, 10:26 AM
  #11
JAFO's Avatar
Default here's a nice toy. this shows the S4/B5 6 speed but you can enter your own info
<ul><li><a href="http://www.car-videos.net/tools/speedrpm.asp?Car=Select&amp;Num1=205&amp;Num2=55&a mp;Num3=16&amp;AxleRatio=4.111&amp;Ratio1=3.5&amp; Ratio2=1.889&amp;Ratio3=1.231&amp;Ratio4=.967&amp; Ratio5=.806&amp;Ratio6=.684&amp;Ratio7=&amp;Redlin e
Old 12-29-2006, 12:24 AM
  #12
Member
Quattro4lifeAus's Avatar
Default That table is AMAZING...Specs for B6 6 speed inside this link...
Save this one to your favourite list.
Big thanks to JAFO for this one<ul><li><a href="http://www.car-videos.net/tools/speedrpm.asp?Car=Select&amp;Num1=235&amp;Num2=45&a mp;Num3=17&amp;AxleRatio=4.111&amp;Ratio1=3.5&amp; Ratio2=1.889&amp;Ratio3=1.320&amp;Ratio4=1.034&amp ;Ratio5=.857&amp;Ratio6=.730&amp;Ratio7=&amp;Redli n
Old 01-04-2007, 08:18 PM
  #13
Member
Yippers®'s Avatar
Most likely drag limited to well below 190 unless you are sporting a far amount of WHP
Old 01-08-2007, 04:10 PM
  #14
Lucas_Gchips's Avatar
Default Re: B6 S4 Gearbox for 1.8T...will that fit?
Bolted up with one small mod that took 5 seconds to engine block.
tail shaft has to be shortened, this can be done for a few hundred bucks.
you will need new shifter linkages and shifter.
if you have a b6, the existing drive shafts should bolt up.
And you have to check where your speedo input is taken from on your car, if its taken from abs sensor then no probs.
Old 01-08-2007, 04:14 PM
  #15
B6 S4 final ratio is 3.888 not 4.111
quattrorally
06-25-2007 06:41 PM
Egil A64.2s - S6
Canadian Discussion
12
02-09-2007 01:59 PM
Quattro4lifeAus
10
12-22-2006 11:42 AM
ingrahamm
03-30-2003 09:45 AM
Quick Reply: Theoretical top speed of B6 A4 Quattro fitted with a 6 speed gear box?
