Thoughts on experimenting with a boost controller...
First thing. I'm a non-DBW T-28 and these are the boost characteristics I have experienced with my 1.5 bar street program.
1st gear spikes to 12psi (haven't seen it settle since I wind up shifting).
2nd gear spikes to ~20psi and settles to ~15psi
3rd gear spikes to ~21-22psi and settles to ~17-19psi.
4th gear spikes to 21~22psi and holds around ~20psi.
Same with 5th gear.
From the reading I've done, I've read that boost controllers are bad for non-DBWs (mainly in response to K03s though). I've also read that it's because we don't have a MAP and we'll lean out the car. This leads me to a few questions...
1) Does the ECU go into open loop mode at WOT (given that it's GIAC non-DBW programming)?
2) If yes to 1), is that the reason I could run lean in the lower gears? I know that the BC would allow me to keep the boost consistent in every gear. However, if the fuel map at WOT does not inject enough fuel at the set pressure (20psi in my case) I'll run lean. Is this a correct assumption? How do the DBW cars deal with this?
3) I'm going to get an MBC (ball/spring) to play with. I've read that EBCs are faster to respond though. Does anyone know how much faster?
My ultimate goal is to smooth out the boost characteristics. Also, can anyone suggest Vag blocks to log (nonDBW) so that I can characterize what I am seeing on my boost gauge?
Thanks.
The DBW exibits this but not nearly as abrupt. Maybe it's the built in delay of getting the full throttle plate opening ...
Running a BC in parallel with the N75 seems to help smooth any boost spikes and helps keep timing lost to those spikes.
RS has a fair amount of experience running a BC on his nDBW APR car .. maybe post a query to him on teh A$/S$/TT forum in that 'other' place?
Bost doesn't really happen with our turbo untill about 2800.. but it is a steady build..no spikes..unless Alex (son) sets it that way.
Alex (son) is bringing it home NEXT weekend to do the final Dyno tune with Mike (www.tyrolsport.com ) he was the mod-shop/guru who made the original package and did the work.
