Torque Wrench basics - store clicker-types at a low setting
Caring for your Torque Instruments
Calibration : Most torque instruments have a factory calibration recommended interval of one year. Many torque instruments may need to be tested multiple times per year depending upon the usage and user needs.
Storage: All torque instruments should be stored in their original case. Avoid any storage locations that are subject to high or low temperatures and high humidity. "Clicker" style torque wrenches should always be turned down and stored at the torque wrenches lowest possible setting.
Usage: Before and after every use, make a visual inspection. Look for any signs for wear or deterioration. Make sure the unit is locked on the proper torque setting before use. Grip handle correctly in the proper position and secure your feet for possible breakage of tool. We recommend safety glasses when using any torque wrench or torque product.
Makes sense. I hadn't thought to turn it down. Do you?<ul><li><a href="http://www.teamtorque.com/tips.htm">http://www.teamtorque.com/tips.htm</a</li></ul>
Speaking of torque wrenches...
Has anyone tried the $30 one tirerack.com is selling? Normally with this kind of price your only get the cheezy gauge type, but this one looks like it's the clicker type. Any ideas on the quality and make?
I bought a Husky tq from there - it's measures 30lb less then what it should.
I'm going to have to send it out and get it recalibrated. Maybe it's a one off, but definately test the lower end models before using.
Monkeyboy
01-06-2006 02:39 PM
Vtec_Killer
10-27-2005 02:25 PM
