Turbo Question
Turbo Question
What would happen to a 1.8t chipped under WOT in a bogged down situation?
Would there be alot of heat produced that wouldn't be able to dissipate?
trifona
'99.5 1.8tqms
trifona
'99.5 1.8tqms
There will be a lot of heat generated regardless...
Unless you have moved to a larger turbocharger, the K03 will generate very significant amounts of heat due to it's inefficiency at boost levels beyond about 6-8 psi.
It can dissipate the heat once you're off the boost.
-Brian
-Brian
should be okay
There is plenty of air flowing through the turbo it acts as a coolant, although an ineffecient one. It won't melt or anything I don't think, but if you are chipped, you'll be able to watch your turbo glow.
Jordan Strasser
10-09-2014 04:18 AM
