UPSOLUTE chipping in MA (xpost) AW directory advertiser
Hi:
Just wanted to let everyone know that I'm now a distributor for Upsolute Chip Tuning.
I'm located in Shrewsbury, MA (ZIP 01545, Metro-West Boston)
If you are interested in getting your car chipped, or are a current Upsolute customer in the New England area and want to say hi, contact me at:
email:
sramsey@upsolute.com
phone:
(508) 212 - 6049
Upsolute has performance software for most Audi, VW, BMW, Mercedes, Volvo, and Porsche.
Check out the main site at:
http://www.upsolute.com
Or, contact me with your car model, year, and ECU number to see what is available.
Regards,
Scott Ramsey
email:
phone:
(508) 212 - 6049
Regards,
Scott Ramsey
Re: UPSOLUTE chipping in MA (xpost) AW directory advertiser
Do you chip the 30V 2.8L V6?
Also, what makes your chip any better/different from a GIAC chip for the same engine?
or an APR Chip?
or a Neuspeed Chip?
(Did I miss any?)
or an APR Chip?
or a Neuspeed Chip?
(Did I miss any?)
Yes,
I have a chip available for the Audi 2.8l 30v V6's. $325 installed or return FedEx'ed if you mail me your ECU. Which car/year do you have?
Advantages?
Probably the biggest is if you are local to me, the install is done while you wait, takes about an hour. I do before after VAGCOM code scans and a test drive. There is a satisfaction guarantee, if you don't like the chip you will be returned to stock and your money refunded minus $25 ECU fee. I'm an experienced EE and have a very good rework setup so you ECU will be handled properly.
Gains? The typical parameters are modified (timing, fuel, speed limit removal, DBW throttle if applicable). Improved throttle response and cruise fuel economy. Neuspeed says 5-6 hp at the wheels from their chip (I think they say that about all their chips), our site lists a gain of 18 hp (crank, probably the euro-spec. car though) so depending on your car you should be somewhere between these two values. Not sure what GIAC claims, their site says "coming soon" for 2.8l chips. APR does not have a chip for this motor according to their site. I don't have a specific dyno. I do the install, the ECU-specific tuning is done by UPSOLUTE.
Drop me an email if you'd like to set something up.
Thanks,
Scott<ul><li><a href="http://www.upsolute.com/db/ger/datenblatt_eng.php?s_FZName=audi&ID=31">UPSOLU TE DATA SHEET</a></li></ul>
Advantages?
Thanks,
scotty_passat
New England Discussion
12-03-2003 12:30 PM
Aftershock
09-12-2000 09:13 PM
