What does the term "setback" mean in reference to an alignment?
Turns out it was easy to fix and they only twiddled with the toe.
But I'm looking at the sheet they printed out that shows the alignment and there's a value called "Front Setback" and "Rear Setback", but I don't know what it means.
Any ideas?
Cross-caster readings in excess of 0.5š without factory adjustment, are an indication that a setback condition exists. When setback measurements exceed 0.5š (some light trucks are the exception), it's possible that a component is bent or positioned incorrectly. To check the lower control arms, for example, compare the caster and setback measurements. "
Try a Google search for "wheel alignment" "setback" for more than you ever wanted to know.<ul><li><a href="http://www.google.com">http://www.google.com</a</li></ul>
