What knock sensor voltage is considered detonation via VAGCOM? (Also chip update on 2.0 conv)
After having no luck getting a chip (I should say, a good running chip) I just put in my GIAC K03 chip with a set of 310cc/m injectors (combined with my homemade 3" MAF), and the car runs great.
It's still only set for 10psi, but I swear it pulls harder once I hit 5000RPM (with 10psi of boost coming on around 3000RPM or so) Must be the VTEC kicking in
The stock MAF measures 2.44" id, so that's 4.676 sq in.
My MAF measures 2.75" id, so that's 5.940 sq in.
That's a 27.02% increase
The stock injectors are 240, and a 27% increase is 305, 310's are close enough.
I just did a 1st/2nd gear WOT run, and my O2 values are in the 0.85 - 0.88V range, which looks OK, it does seem to fall off a little in the upper RPMs (starts off at 0.88V and drops to 0.85V)
I was hitting 175g/s at 6500RPM, and corrected thats 220g/s (40g/s more than my K03 had on it's best day)
Sadly, I think the 310 injectors are maxed out at ~220g/s, the 240's were maxed out at ~175g/s, so that seems about right.
Because the ECU is actually reading the wrong MAF values, the load values will be off, so it could be running more/less fuel and timing than it should. I want to make sure that it doesn't start detonating because of lean mixtures, or too advanced timing.
So, back to the question at hand, what kind of knock sensor voltages equal detonation?
I was seeing 1350F-1400F during highway cruising (3400RPM), and 1550F WOT (not extended though)
Now when you say safety, is that safety for the turbo, or the motor?
My probe is in the manifold too.
Mike@StartupRacing
9
08-15-2006 08:35 AM
laissezfaire
05-25-2003 03:37 PM
maxma
14
01-02-2003 07:48 AM
System_S4k
12-21-2001 02:35 PM
