who makes 880cc injectors for a4?
880cc!!!....
how big a turbo are you putting on this monster?<ul><li><a href="http://clam.rutgers.edu/~dreadsct/resell/1.8T_injectors.htm">http://clam.rutgers.edu/~dreadsct/resell/1.8T_injectors.htm</a</li></ul>
Re: Having the injectors at diff. angles like that...
doesnty that cause all your fuel to run down the cylinder walls. Looks like that would cause diff. combustions in each cylinder.
Might want to look into that.
Re: What are you talking about?
As long as the fuel is mixing evenly you are fine. Just make sure the research has been done on the spray patterns since I ju8st took and hacked up a manifold I can see the extreme lengths Audi has gone through. With those huge injectors you run, your increased airflow,and diff. spray pattern on the injector vs. stock seems that the variables have changed slightly andyou may want to test out some slight variations.
So hows it coming along? Havent seen you this quiet in a long time on AW.
Re: 580cc is the biggest drop-in injector I've found....
I've had the 780cc(I think) RC injector in my hand. Should be up for sale in the next week. The holes are freakin huge! Kinda scares me:-)
I gotta see these injecotrs spray patterns in action. I cant say too much about them yet till I throw a set in my car to try.
