Will installing an electronic boost controller be the same as it was on the older s4?
I'm planning on installing an EBC with my t28 kit and was just wondering if it will work if I follow these instructions...<ul><li><a href="http://home.pacbell.net/gj_os/evcinstl.html">http://home.pacbell.net/gj_os/evcinstl.html</a></li></ul>
I think those instructions are for a external wastegate.
For a internal WG you just remove the 2 lines from the turbo housing and the wastegate. Take one of those lines off the N75 valve and loop the other one around so it caps off the other nipple where you removed the first line.
Now just take the 2 big lines from the BC unit and run one to the turbo housing and the other to the wastegate. If the bc unit has a small line then you will T that into the vac line that goes to the BPV.
If you have any other questions feel free to ask, you can email me or catch me on AIM at scac cmh.
AWD2KS4
12
10-20-2008 07:19 PM
matt13
01-05-2006 03:50 PM
LCP
03-11-2005 08:27 AM
Bob Dobalina RS
01-14-2003 07:53 PM
