Active Lane Assist Retrofit In Progress - Need Help
Old 05-27-2015, 09:17 AM
Club AutoUnion
Mrclopec's Avatar
Default Active Lane Assist Retrofit In Progress - Need Help
Hello!
I am now onto my next retrofit project! I am going to attempt to retrofit Active Lane Assist. I have acquired all but 1 item needed for the retrofit and I'm hoping some of you coding gurus can shed some light on this for me.
I acquired the new turn signal switches with the Active Lane Assist button on the stalk. It has been installed and 16 - Steering Wheel has been coded to reflect it. This was a tricky one because VCDS displayed the check box to enable lane assist but then the system was giving an error for the vibration motor in the steering wheel. MY13>Current no longer uses the motor. I cross referenced another VCDS scan from a 2013 Q5 with Lane Assist and found there was a bit that is not displayed in Long Coding that needed to be enabled. Once enabled the system took the error away.
I acquired the Active Lane Assist camera for the windscreen and hooked it up to the CAN system. I coded the camera based on my vehicle (Q5, Only USA, Without Adaptive Suspension/With Adaptive Cruise)
I am getting an error that the windscreen heater is not connected - This is okay as I have not changed the windscreen yet.
I am getting an error that the module does not have basic settings/adaptation - This is okay as I will be calibrating it later.
I am getting an intermittent signal/communication error with 46 Central Convenience and 13 Auto Dist. Reg. - These are confusing me as there are no documented bits within these modules to reflect Active Lane Assit.
And most importantly I am getting an error that the control module is incorrectly coded.
Would anyone with a 2014 or 2015 Q5 be able to pm me with a VCDS scan that I can use for comparison or if anyone has any information that you might think is useful I would greatly appreciate it. When all is done I will be doing a full writeup with photos.
Below is a scan of my car before any retrofits or coding as well as a scan after retrofits and coding.
BEFORE:
Code:
Thursday,09,April,2015,11:04:40:00104
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
www.Ross-Tech.com
VIN: WA1WMBFP6FAXXXXXX   License Plate:
Mileage: 16350km-10159mi   Repair Order:
Chassis Type: FP (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 36 3C 42 44 46 47 52
          53 56 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FA048050   Mileage: 16350km-10159miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1B-Active Steering -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
AC-Reductant Control -- Status: OK 0000
Address 01: Engine (J623-CPNB)       Labels: 059-907-311-CLA.clb
   Part No SW: 8K5 907 401 S    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0001
   Revision: 58H14---
   Coding: 2A2A4012057603050000
   Shop #: WSC 55440 001 1048576
   ASAM Dataset: EV_ECM30TDI0118K5907401S 001003
   ROD: EV_ECM30TDI0118K5907401S.rod
   VCID: 408F6B65DB83AB212EF-8015
1 Fault Found:
8812 - Cylinder 2 Internal Pressure Sensor
          P13D1 00 [047] - Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 6
                    Mileage: 12828 km
                    Date: 2015.03.14
                    Time: 10:40:38
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1003
   Revision: --H19---
   Coding: 000001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMAL551211 002022
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 4B954C49E2C57879CBD-801E
No fault code found.
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
   Component: ESP8 quattro  H09 0020
   Revision: --------    Serial number: --------------
   Coding: 23AD1C03
   VCID: 11299E21C86912A9F11-8044
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 KP    HW: 8K0 907 064 KP
   Component: BCM2 2.0      H15 0711
   Revision: 00002001
   Coding: 0DA54040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 081FB345BB33536126F-805D
   Subsystem 1 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Component: J764 ELV MLB  H40 0046
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Component: KLIMA 3 ZONEN H04 0122
   Revision: C1000000    Serial number: 01190920141164
   Coding: 3621228080
   VCID: 77FDC0B9C6CD2C995F5-8022
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Component: BCM1 1.0      H16 0103
   Revision: 09016001    Serial number: 00000893404802
   Coding: 26000091867CAFF21100488300003D0D4F9CE708A6090221000008004000010200040034000000
   VCID: 7AFBD98DF5DF31F120B-802F
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140827  H12 0050
   Coding: 01DD13
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Component: G397_RLFS  H06 0002
   Coding: 02005C
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
H05 0012
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Serial number: 00000000000000
   Coding: 008157
   VCID: 377D00B9864DEC999F5-8062
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NED12HYXB
   Coding: 303334313432383132304A55304C38523053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4C974F55E7CB7F41C27-8019
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Component: BF-Gewichtss.  H02 0040
   Serial number: 5810000R140000GX4R
   Crash sensor for side airbag; driver side:
   Serial number: 6334MSME480E2C00D
   Crash sensor for side airbag; front passenger side:
   Serial number: 6344MSME4879646DV
   Crash sensor for side airbag; rear; driver side:
   Serial number: 6352QSME5C460456J
   Crash sensor for side airbag; rear; passenger side:
   Serial number: 6362QSME4747316EO
   Crash sensor for front airbag; driver side:
   Serial number: 63732SME40443466U
   Crash sensor for front airbag; front passenger side:
   Serial number: 63832SME64424D44+
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H04 0005
   Revision: --------    Serial number: 90372NIG000A4
   Coding: 00003F
   VCID: 44876775C79BB7010A7-8011
   Component: E221 - MFL  H03 0004
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 982 B    HW: 8R0 920 982 B
   Component: KOMBIINSTR.   H35 0564
   Revision: 00400000    Serial number: ZDC27399F
   Coding: 8BBF22002F01D705020000
   VCID: 3A7B198DB55FF1F160B-806F
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z149050B6E
   Coding: 80CF07FF00
   VCID: 4C974F55EFCB7F41C27-8019
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Component: J532_DCDCStab  H05 0006
Address 1B: Active Steering (J792)       Labels: None
   Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
   Component: DYNAMIKLENK.  H06 0730
   Revision: 52001005    Serial number: --------------
   Coding: 020100
   VCID: 39790681B059FAE9691-806C
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   Shop #: WSC 06325 000 00000
   VCID: 7CF7DF95FFEB0FC1327-8029
Address 36: Seat Mem. Drvr (J136)       Labels: None
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000114744385
   Coding: 01581B00000000000000
   VCID: 428B616DDD8FB93138B-8017
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H05 0071
   Serial number: 0346139735
   Coding: 010221
   ASAM Dataset: EV_LaneChangAssis 001020
   ROD: EV_LaneChangAssis.rod
   VCID: 3F8D6899A67DD4D9575-806A
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 R    HW: 8K0 959 793 P
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000116313843
   Coding: 011D13215E00440004
   VCID: 4FAD58591EDD4459A75-801A
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0030925634
   Coding: 010000010001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X.rod
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0347056755
   Coding: 0126063A20FA709584A0053600040047
   Subsystem 1 - Part No SW: 8K0 959 719 B    HW: 8K0 959 719
   Component: GTO BF  H01 0080
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T1 035 223 A    HW: 8T1 035 223 A
   Component: DSP Prem      H05 0030
   Revision: 00005001    Serial number: 94813034061406
   VCID: 2D5122D174115649F59-8078
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 R    HW: 8K0 959 792 P
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000117929946
   VCID: 4E93455D19D74D51AC3-801B
Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000264223
   ASAM Dataset: EV_ParkiBrake 001028
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B198DBD5FF1F160B-806F
Address 56: Radio (R)       Labels: Redir Fail!
   Part No SW: 4G0 035 082 G    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156I20E8065591
   Coding: 020007010000000001
   VCID: 2447C7F527DB97012A7-8071
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8R1 035 746 F    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0812
   Revision: --------    Serial number: 204I10E7679622
   Coding: 160200060005E9EF7502AF5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CA
   Component: NAR 2014  1002
   Subsystem 2 - Part No SW: 8R0 919 604 A    HW: 8R0 919 604 A
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0030
   Subsystem 4 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 G    HW: 8K0 959 795 D
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000117821679
   Coding: 010C13204000240004
   VCID: 46837D7DF1A78511143-8013
Address 69: Trailer (J345)       Labels: 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H09 0100
   Revision: 1A001001    Serial number: 00008200724693
   Coding: 0200000000000000
   VCID: 36630DBD81471591843-8063
Address 6C: Back-up Cam.        Labels: 4L0-910-441.clb
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Component: J772__Rearview      0040
   Revision: --H09---    Serial number: 525PA8-J47A2YG
   Coding: 1031010
   VCID: 346737B5573B0781BA7-8061
Address 6D: Trunk Elect. (J605)       Labels: Redir Fail!
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D711291A471C6C9459-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000116472682
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 142460205
   ASAM Dataset: EV_RDCMA00100 008040
   ROD: EV_RDCMA00100.rod
   VCID: 2D5122D17C115649F59-8078
End-------------------------(Elapsed Time: 04:43)--------------------------
AFTER:
Code:
Chassis Type: FP (8R0) (2015 Q5 TDI 3.0)
          53 56 5C 5F 62 69 6C 6D 72 AC
VIN: WA1WMBFP6FAXXXXXX   Mileage: 17380km-10799miles
5C-Lane Maintain. -- Status: Malfunction 0010
   Revision: 58H14---
1 Fault Found:
          P13D1 00 [109] - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 17382 km
                    Date: 2015.05.26
                    Time: 01:38:04
Readiness: 0 0 0 1 1
   Revision: --H19---
   Coding: 000001
   Coding: 23AD1C03
   Revision: 00002001
   Coding: 3621228080
   Coding: 01DD13
   Coding: 02005C
H05 0012
H05 0012
   Coding: 008157
   Coding: 0000FF
   Coding: 8BBF22006F01D705020000
   Coding: 80CF07FF00
   Coding: 020100
   Revision: AA001002
   Coding: 010221
   Coding: 010001010001
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600213910000FA
   Coding: 0002004
   VCID: 377D00B9464DEC999F5-8062
5 Faults Found:
02797 - Control Module for Directional Stabilization Assistance (J759)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 17382 km
                    Time Indication: 0
                    Date: 2015.05.26
                    Time: 21:01:37
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 237
                    Mileage: 17382 km
                    Time Indication: 0
                    Date: 2015.05.26
                    Time: 21:01:37
02858 - Windshield Heater for Directional Stabilization Assistance (Z67)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 17382 km
                    Time Indication: 0
                    Date: 2015.05.26
                    Time: 21:01:38
01330 - Central Control Module for Central Convenience (J393)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 17382 km
                    Time Indication: 0
                    Date: 2015.05.26
                    Time: 22:12:21
02001 - Data-Bus Automatic Distance Regulation
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 22
                    Time Indication: 0
   Coding: 160200060005E9EF7D02AF5E00000403140000000000000000
   Coding: 1031010
End-------------------------(Elapsed Time: 05:11)--------------------------
Old 05-28-2015, 09:41 AM
Club AutoUnion
Mrclopec's Avatar
I found the problem. The 5th digit needed to be a "3" as I have both Advanced Key Authorization and Navigation. Active Lane Assist uses the following coding structure for the facelift Q5:
Structure of the coding value (7 positions): 7654321
Position 1 and 2 (xxxxxXX):
xxxxx04 A Audi Q5
Position 3 (xxxxXxx):
Country version:
xxxx0xx = Country variant 1: A Rest of the World with Canada
xxxx1xx = Country variant 2: A only USA
xxxx2xx = Country variant 3: A only Great Britain
xxxx3xx = Country variant 4: A only Japan
Position 4 (xxxXxxx):
Optional extra
xxx0xxx = without adaptive suspension (PR number: 1BA, 1BV, 1BW), without adaptive cruise control (PR number: 8T1, 8T0)
xxx1xxx = with adaptive suspension (PR number: 1BK), without adaptive cruise control (PR number: 8T1, 8T0)
xxx2xxx = without adaptive suspension (PR number: 1BA, 1BV, 1BW), with adaptive cruise control (PR number: 8T4)
xxx3xxx = with adaptive suspension (PR number: 1BK), with adaptive cruise control (PR number: 8T4)
Position 5 (xxXxxxx):
Optional extra
xx0xxxx = without advanced key, without navigation
xx1xxxx = with advanced key, without navigation
xx2xxxx = without advanced key, with navigation
xx3xxxx = with advanced key, with navigation
Position 6 and 7 (XXxxxxx):
Towing Controls
00xxxxx = No towing module installed
01xxxxx = Towing module installed
Old 05-28-2015, 10:19 AM
snagitseven's Avatar
Another poster tried this three years ago. Had all the hardware but was never able to get coding to get it operational. You would be the first in these forums to get it to work. Good luck.
https://www.audiworld.com/forums/a7-...-done-2826064/
Old 05-28-2015, 01:17 PM
Club AutoUnion
Mrclopec's Avatar
Thank you! I already created a vector copy of the VAS 6430 (Lane Assist and Adaptive Cruise Calibration Board) in Adobe Illustrator. Its at the printing business right now being printed on their large printer. Calibration is all thats needed to verify it works. Once it works I will then change the windscreen. DIY is on the way!
Old 05-28-2015, 01:55 PM
BillBoost37's Avatar
when you say windscreen, are you talking about the windshield?
Old 05-28-2015, 02:56 PM
Club AutoUnion
Mrclopec's Avatar
Yes.
Old 05-28-2015, 04:13 PM
You have your own VAS6430 adjustment jig to hold the board?
Old 05-28-2015, 05:53 PM
Club AutoUnion
Mrclopec's Avatar
I will be improvising. Stay tuned
Old 05-29-2015, 08:46 PM
Club AutoUnion
Mrclopec's Avatar
Oh yes.....This IS happening...
Im just very thankful to have a spouse that is supportive enough to put up with my neurotic obsessions.
Old 05-30-2015, 09:38 AM
hilld's Avatar
If she is anything like my wife, she just rolls her eyes and says whatever.
Quick Reply: Active Lane Assist Retrofit In Progress - Need Help
