Any tips from existing Q5 DIY'ers on jack points, pads and otherwise
#11
It's not something you would normally think of, but when you consider its purpose (to haul a 5000 lb trailer) then it would be safe to assume it can take the weight of the car itself too. Just be sure to jack it on the strong part of the hitch assembly preferably near one of the welds - NOT where the receiver tube is.
#12
Great thread! Have been searching the web for this as well so I could start doing my own oil changes via the gravity drain method.
I'm a little uncomfortable about crawling around underneath without jackstand supports though so was looking for some way to use those as well. But there's a catch 22 - seems like the only reliable suspension point for a jackstand would be the same spot where the jack is used - on the pinch weld...
#13
AudiWorld Expert
However, on this topic, I'll note that on my S4 I was able to fit the jack and jackstand like this:
However later on I found it just easier to jack it really high in the rear and put the jackstand under the front, using proper locations for each.
If you really want to get crazy, you can get these Jackpoint (http://www.jackpointjackstands.com/) jack stands designed to fit the jack inside the jackstand for using a single specific jack point:
#15
AudiWorld Expert
BTW, I can't tell you how hard it is to find an (ice) hockey puck in North Carolina. I thought for sure Dick's Sporting Goods would have it, but nope! I think they said "oh a hockey ball" or something like that I ended up finding one somewhere, but it escapes me now. I never considered it would be hard to find down here.
#16
Thanks; lots of good info and options here
Lots of good info and product ideas in here.
Yes, from one of the replies, just using ramps (which I have) makes sense here for the oil change type stuff. For seasonal tire changes or (eventually) the brakes, I'll have to jack up corners.
And yes, from another reply I definitely use (2") hitches as a central jack point in the rear; sturdy, well bolted in, etc. And if I ever had an issue with strength somehow I would way rather find it out in the garage than during sudden hard braking or acceleration forces pulling my boat; steel is really just too robust for that though. I've been doing the same for years on the 2" hitches on the preceding minivans. The Q5 distance from the hitch to ground is greater than minivan sort of scenarios, but at least with my decent sized floor jack, the Q5 is still gets an inch plus off the ground at the bottom of the tires w/ the shock/spring fully extended. Using a jack point like that typically gives me more options for jackstand placement too.
#17
Just buy Rhino Ramps for doing oil changes. Much simpler and no reason to worry about jack stands, pinch welds, proper support, etc.
Happy Thanksgiving to all our American friends!
#18
While I love the idea, I'm concerned that these Jackpoint jackstands aren't high enough for the Q to fully service the wheels/tires though.
Does anyone have experience with them directly for the Q?
#20
You do need to get a fairly high jackstand. I use the Esco Jack stands with the flat rubber tops and a AC floor jack. I had the Q5 up on all 4 jackpoints to do a wheel change as well as brake fluid flush. Rear I jacked up from the diff mount, front I believe it was the cross member. You do need a long reach jack to make it easy.
