Can I tow with 2.0?
#11
No problem, I tow a 2900lb tent trailer regularly and the 2.0T tows like a champ! The low end torque gets you moving and it has no problem maintaining speed up mountain passes.
#12
Define "mountain passes" as I have to be on manual and keep rpm's up to 4-5k while climbing up I-70W towards the Eisenhower tunnel at 12000 feet on Colorado Rockies.
#13
I climb nothing close to 12000ft. I live in washington so I travel over Steven pass frequently (6000ft) is the maximum elevation. The car tends to settle in around 3000RPMs going up steep grades at 70mph.
#14
#15
Stevens pass essentially starts from sea level too, at least from from the west. Although I think the top is only a bit over 4000 feet along highway 2.
#16
My 3.0TDI is nothing short of a tug boat but I'm yet to really test it out with anything that stresses it. I opted for the 3.0TDI for both it's towing performance (occasionally need to pull a car carrier) and it's outright performance (0-100km/h in 6.5sec).
I'm quite sure the 3.0TDI Touareg will suit your needs and wants very well indeed.
#17
Crusty you are right and combined with miles long steep climb where 18-wheelers use their low range, I can see the difference.
At lower altitudes all I need shift down one gear and 3.2L keeps going but up there I have to keep it manually 2 or 3 gears down for uphill power and on other side for engine brake power so I don't need to stand on the brakes itself.
I would really like to try 2.0 T with its 8 speed and low end grunt to pull my trailer to see how it goes the Rockies. I bet with its turbo, higher torque and better gearing it should be pretty good.
Anyways, I take TDI over gasser any time as I got spoiled with TDI torque and good mileage back home in Europe. I actually bought my first gasser when I moved to States and pretty quickly found myself getting annoyed by the constant down shifting gassers do with lack of low end torgue.
I have been snooping around the Touareg forums and the new T3 without the transfercase gets really good mileage for its size and guys towing heavier than I still gets better mileage than I. I don't need H/L tranfercase so new TDI Touareg seems to be answer.
#18
I've not had an opportunity to really test mine yet, but as I live at over 5,000 ft. And occasionally drive tomthe coast through the Sierra Madres, I'm looking forward to seeing how my TDI performs. My first diesel!
ramjet44
Audi 100 / A6 (C4 Platform)
05-06-2007 02:45 PM
I thought of an analogy for sprung vs unsprung weight.Imagine running w/weight attached to your feet
Audi Junkie
11-25-2002 09:20 AM
