Car keyed
Car keyed
Hey all.
Not a happy day. Owned the car for less than 2 months now and it’s been keyed. Thankfully just the rear passenger door.
Ive gotten a police report and will discuss with my insurance potentially covering it (cost benefit for the increase in premium vs. cost of fixing it).
In the meantime im asking if anyone has a reputable shop in the Central Maryland area they would trust to repaint. I live in Baltimore but I’m constantly in Northern Virginia and I’m willing to travel for someone’s referral. As well - if anyone has had experience with this type of repair and can say what they paid so I can determine whether I’m getting a fair deal or not.
While im at it - I’m considering getting my car serviced independently to hopefully save some $$. Is that a realistic concept? And if so - anyone who can refer an independent service professional near me as well.
Vehicle is a 2015 Q5 PP in midnight blue (not sure if that’s the real color name - but if you’ve seen it you’ll know what I’m referring to).
Thanks all.
Thanks all.
Hey all.
Thanks all.
Thanks all.
Is that really a key'd job? When people key they usually have a straight line and go a much longer distance.
Is it a deep scratch through the clear coat and through the paint to the primer/metal?
If it is just a shallow scratch in the clear coat you should be able to wet color sand it and buff it out.
If you want a good match, with it blended into the front door and rear quarter panel properly, and have the correct final paint surface texture to match the rest of the Q5, then you need a top of the line body shop.
That's sad, happened to me twice, but I do my own painting so can't comment on cost.
I would have to assume it was a key job. Living in the city and my particular neighborhood, we get terrorized by the Baltimore youth. As I didn’t see it happen, I can’t speak specifically to what exactly it was. But it’s through the paint into the metal. If you zoom in on the photo you can see how significantly wide the scratch is and the significant color change from paint to metal.
Again, worse case is to paint the door blending into the side panels. I have seen some dealer touch up guys do amazing work of just filing in the scratch, but it was always noticeable. If you feel that you could be vandalized again, maybe that is the better way to go.
If that happened someplace where you often go, it may happen again after you fix it.
Matching metallic paints of any kind is not easy. To repaint the door, you need a shop that will guarantee the work will match perfectly--and that's hard to get in writing.
It may be better to simply have it polished out as best they can, and retouched/filled as best they can, without attempting to shoot the entire door. You'll probably still see a lesser scratch....but if you park back in the same place and the same guy sees you've undone his/her work, and then does it bigger and better....Yeah.
dramaticstatic
15
08-09-2004 02:27 PM
