Chugging humming
Chugging humming
I posted something pertaining to this but it's gotten worse. At 38 mph- 60mph then after 77 mph I hear a rhythmic humming. It happens about once a second no matter my speed. I am just now starting to be able to feel a slight pull with the vibrationing humming. I go in on Monday to check it out. Any ideas what it could be? My husband says a wheel bearing but I think it's more than that. It's a 2012 Q5 with about 50,000 miles on it. New tires and an alignment a few weeks ago. Didn't fix the issue.
On a deserted road at the slow speed where you hear the noise, swerve the Q5 back and forth, across the highway. If in one direction you hear the noise, and then no noise in the other direction, usually indicates a bad wheel bearing.
I've done the swerve test. It does it regardless. Speed is the only thing that matters and I've sat shot gun and the vibration and humming sound is the same in the passengers seat as the drivers seat. I did purchase the extended warranty. I pray this is covered.
Audi Convert
A6 (C7 Platform) Discussion
12-09-2015 03:21 AM
slightly disgruntled
04-09-2007 02:19 PM
S4Pazz
05-06-2006 05:33 AM
daseighty
14
04-01-2005 07:50 AM
