Is the glovebox cable the only way to play music from an iPhone?
I haven't been on the forum in a while, and a search turned up too many topics to go through, so I wanted to ask if the best (and/or only) way to play music from my iPhone is via the cable in the glovebox?
I remember seeing some threads where someone bought a device online that might allow for Bluetooth to work (or something like that) but I can't find that topic to see how it turned out.
Thanks!
Thanks!
AudiWorld Expert
But when it comes to sound quality, I think another poster here who researched this stated that BT connection is probably your worst option.
Edit: BTW any wireless connection will not be as good as a physical connection, since all wireless signals degrade. BT is actually very good, but still degrades(even if it is close to the its receiver) and audio will suffer the further it is from its receiver. Another example, a WiFi connection will still be quick using fast WiFi equipment, but not as quick as connected via an Ethernet cable. If you want the best audio quality connect via cable, but if you want convenience, BT will be good enough unless your an audio enthusiast.
Quick follow-up question: I purchased an adapter to convert the glove box 30-pin cable to a lightning cable so I could connect my iPhone 6. The cable 'works' in that the phone charges, but it doesn't work in that the car doesn't 'see it' (i.e. I can't select it as a source). It works fine w/o the adapter using an iPhone 4.
Any thoughts?
Any thoughts?
Any thoughts?
Any thoughts?
My dealer was going to send me a lightning cable to replace the one in the glovebox, but suggested using an adapter called Tune2air wireless bluetooth adapter sold on Amazon (which only is available for the old iphone connector in the glovebox). I could then stream audio via bluetooth and wouldn't have to leave my phone in the glovebox and reach over every time. I haven't ordered one yet to try it out...
