Head light cleaning
I have done this as part of regular maintenance of the exterior.
B
Hazy glaze? If you are someplace like Florida or Texas, the heavy UV in the sunlight will eventually break down all the plastic headlight "covers". There are products supposed to prevent that, and others that will resurface the headlight plastic every 3-5 years or so, as it hazes up again. If the "haze" is just road dirt...washing keeps it off. I'm not certain I'd trust any "protectant" unless it came from a brand name with a replacement warranty, in case it failed in two or three more years, and caused more damage.
Clay bar is basically a 3000-grit abrasive putty, the same as 3M's "Finesse" compound, except being a putty bar instead of a cream, it is easier for some folks to work. The "Novus" plastic polishes, sold in 3 grades or as a kit, will do the same thing as well. Pop-up headlights or glass sealed beams are the only things immune to UV damage.
But the headlight "mask" stuff, is illegal in many (all?) states. Not likely to be caught, but a good excuse to have your car impounded for an equipment violation if someone wants to play nasty.
Keep in mind, the headlights are almost always coated, not just raw plastic. You use too much abrasive on it and remove the coating, and you will find they yellow and pit much faster. I just clean mine and wax them with the rest of the car. Headlights are getting better all the time and way less likely to fog over if you just keep them clean.
Of course desert dwellers have the intense sun and heat to deal with, and the Northern people the salt impact, so wax them up boys!
Make sure that your headlights are in fact coated, and not "just" plastic, if you are going to wax them. Almost all waxes contain petrochemicals, and petrochemicals will cause hazing and crazing and yellowing on all "plastic" glazing materials, both acrylics and polycarbonates. The manufacturers of those materials expressly say to keep all petrochemicals, including waxes and polishes that use them as solvents, away.
Plastic coatings? You might have the same problem, you'd need to find out what the coating is.
