List of common adaptations?
Old 12-25-2020, 08:53 AM
Barraged's Avatar
Default List of common adaptations?
I’ve searched the forums but have yet to find a list of the 100ish most useful adaptations possible thru VCDS or OBDEleven. Has anyone found one or put one together?
Also want to thank the experts on this forum for sharing their knowledge and collective experience... we all benefit from this brain trust.
Best wishes for a better 2021.
denzelm (11-25-2023)
Popular Reply
12-26-2020, 12:41 AM
spijun
spijun's Avatar
This is the oldest list of modifications with VCDS:
http://www.audienthusiasts.com/VagCom.html
I think there is somewhere on the forum but here again, it is not the final list:
__________________________________________________ __________________________________________________ ______________________________
  • Enable Adaptive brake lights
  • Enable Ambient Interior Lighting Control
  • Enable Automatic Gear selection shown in DIS
  • Enable Automatic Hill Hold Assist 'lite'
  • Enable Auxiliary ventilation
  • Enable Battery meter
  • Enable DIS with Efficiency Program
  • Enable Double Disarm Beep
  • Enable DRL Selectable via MMI
  • Enable DRL
  • Enable Euro parking lights that turn on signal at night
  • Enable fog lamp to come on for the same side as that turn signal
  • Enable Front Turn Signals as Parking lights
  • Enable Gauge Test/Needle Sweep
  • Enable Hidden menu in MMI
  • Enable Import CDs to MMI's HD
  • Enable Independent Fogs control with high beams
  • Enable Lap Timer
  • Enable LEDs remain bright for parking lights
  • Enable Rear Tail Lights on with DRLs
  • Enable Release Parking Brake without putting foot on Brake
  • Enable Release Parking Brake without putting seatbelt
  • Enable Remote Operation windows&sunroof
  • Enable Reverse mirror tilt
  • Enable Speed through MMI
  • Enable TPMS
  • Enable VIM on MMI
  • Set Audi parking system - Switch OFF Speed
  • Set Custom ADS settings
  • Set Headlight washer - cycles
  • Set Headlight washer - duration
  • Adjust Consumption in DIS
  • Adjust LED Brightness
  • Disable After-wipe of windscreen wipers
  • Disable amber corner lights
  • Disable amber side markers
  • Disable Key warning (keyless models)
  • Disable LED 'wink' on turn signal
  • Disable "Lights are on" warning
  • Disable NAV & Phone warning messages while entering data at speed
  • Disable Seatbelt Chime
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic Hill Hold Assist ‘lite’
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
Enable Headlights on all the time
Bit 5 - Check the box or change Bit 5 Set to 1)
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the "Bootloader"
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 - Check the box for "Lap Timer active"
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Bit 7 - DRL's via Tail Lets Active (1 = Active)
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
Enable Release Parking Brake without putting seat belt
[Adaptation - 10] -> Channel 7 Set to 0
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
[56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
Does not work if NAV equiped
Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
Enable VIM on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
[17 - Instruments]
[Adaptation - 10] -> Channel 3
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
Set Automatic Transmission Start Mode to D or S
[09 - Cent. Elect.] [Security Access - 10]
[Adaptation 10] -> Channel 64 - Stored Value = 218 = Starting mode is always D
Channel 64 - New Value = 00; Starting mode is determined by ADS selection at engine shutdown (Comfort and Auto=D, Dynamic=S, Individual=whatever you pick)
Channel 64 - New Value = 03; Starting mode is always S regardless of ADS selection at engine shutdown (opposite of stock)
Channel 64 - New Value = 11; Starting mode is S with all ADS settings at shutdown except Comfort where it's D
Channel 64 - New Value = 19; Starting mode is S with all ADS settings at shutdown except Auto where it's D
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
ADD:
Old 12-26-2020, 12:41 AM
spijun's Avatar
  • Enable DRL
  • Enable Lap Timer
  • Enable TPMS
  • Enable VIM on MMI
Reset MMI
Bit 1 – Set to 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Reset MMI
or
change 0 to 255
Add 4
Bit 5 set to 1
Enable DRL
Bit 0 - Set to 1
change 0 to 1
[Hidden menu]
Import Media
Enable Lap Timer
Bit 2 - Set to 1
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
Enable VIM on MMI
Set to 255
Reset MMI
[09 – Cent. Elect.]
change to e.g. 500
[09 – Cent. Elect.]
change to e.g. 10
[17 - Instruments]
DIS: 9,3 l/100 km.
DIS: 23 MPG.
Submodule 0
ADD:
The following 11 users liked this post by spijun:
ACQT (07-11-2023), Barraged (02-28-2021), DennisMitchell (12-31-2020), drgertol (03-12-2021), GreyCoupe (05-11-2021), Phunk1e (03-02-2021), Q5 3.0 (11-21-2023), Q5-3.0 (12-26-2020), rdA4WtQ5 (12-26-2020), rez (12-26-2020), steveg1003 (05-10-2021) and 6 others liked this post. (Show less...)
Old 12-26-2020, 02:24 AM
Bob Petruska's Avatar
spijun, excellent list!
Old 12-26-2020, 10:09 AM
greasykid's Avatar
Does anyone have a list like this for a B9. Pls reply or pm me.
Old 12-26-2020, 11:21 AM
spijun's Avatar
I hope you know that you need to have a new version of VCDS cable with UDS Protocol, to be able to encode and adapt on B9 models
Thanks Bob
Old 12-27-2020, 05:45 AM
Barraged's Avatar
Spijun,
Thank you... this is perfect. Appreciate all of your help again in 2020!
Old 02-28-2021, 12:06 AM
spijun's Avatar
I found (on OBDEleven forum) disable door chime when opening the door with ignition ON or engine ON.
Disable door beep
46 Comfort System > Adaptation > Channel 98 > change value from 1 to 0 (zero)
Then:
46 Comfort System > Coding > Long Coding > Byte 15
Activate/check bit 0 & bit 3.
If no check boxes there so, need had to put in the binary: 01001111
After using this binary, the last two digits for my coding changed from "00" to "4F"
The following 4 users liked this post by spijun:
Dudealicious (03-01-2021), korey_s (03-07-2021), Q5-3.0 (03-02-2021), rez (03-02-2021)
Old 03-01-2021, 01:54 PM
Dudealicious's Avatar
Disable door beep
Then:
I can confirm that this coding does work. No more incessant beeping when I open my door. FINALLY!
I used VCDS v21.3 and there was no tick box so I had to manually enter the binary code.
If you're tired of having to push the button on the wiper stalk in order to stop the beeping then this is the mod for you.
Thanks
Q5-3.0 (03-02-2021)
Old 03-02-2021, 11:48 AM
spijun's Avatar
I'm glad I helped you
The following 2 users liked this post by spijun:
Old 03-06-2021, 09:09 AM
Banned
02ALMSTT's Avatar
Disable door beep
Then:
You are my HERO! That alarm sound is one of the most annoying things they could have added to the system for such a trivial thing. This should be disabled by default.
Quick Reply: List of common adaptations?
