Looking for Security Access Code for VCDS/VAGCOM Module 55 - Headlight Range
Just like the title says. I'm using VCDS 15.7.4 and the recommended security access code, 61378, does not work on my 2011 Q5 with Xenon Plus installed. Anyone have a clue?
Thanks. Will give that a try.
I'm actually not trying to do anything really except figure out what went wrong. Basically, I was in VCDS last night working on a few other basic/safe tweaks (aka - well-documented ones) and I opened the 55-Headlight Range module then 07-Coding. I did not change anything at all but upon exiting I got the yellow warning in the DIS of "Headlight Range Control Defective". I attempted to clear the DTCs but the warning came back. Eventually I found this procedure on the Ross-Tech site and the lights "relearned" their position:
http://wiki.ross-tech.com/wiki/index...ol_(Xenon_Plus)
I was then able to clear the codes and the warning is gone. The issue that I have is that upon startup, the lights no longer auto-level. They illuminate and stay put. I figure there's got to be a way to reset the system but I suspect I need the Security Access number to do so.
Make sure you're on a level surface.
55 - Xenon Range
Go to Basic Settings - 04
Then in the drop down list, select the adaptation/adjustment option
Then click the ON/OFF/NEXT button.
You need to wait 20-30 seconds
Close controller and you're done.
Club AutoUnion
Accessing the 55-Module's coding and then exiting out should not cause an error. It sounds as if something in coding may have been mistakenly changed without you realizing it. I would go into your vcds debug folder and open up codinglog.txt. It will tell you if any coding was changed on that module. If you see any line items there pertaining to module 55, go back and reverse those changes.
No need for VCDS...........
