MMI 3G high flashing wrong fw
Hi , my navi 3g high flashing wrong fw and now not acepted org fw ..
Flashed fw MU9894
Try now flashing MU9307 and not start
My navi is emergency mode and only freeezing ,please help me
Flashed fw MU9894
Try to found the new combination for Greenmenu
If you can find a combination, please contact me for further instructions
PS: drugi put ne diraj nesto sto ne znas
Did you re-enable the green menu? (WITH VCDS )
OR TRY THIS SCRIPT
https://mega.nz/#F!PzpyUIKJ!OL_JGI68ewVl-v-gfZo0fw
- Connect with module 5F – Control Head.
- Choose procedure 10 – Adaptation.
- Choose Channel 6.
- Read stored value. By default it should be 0.
- Change value to 1 and save it.
- Read stored value. Now it should be 1.
- Exit.
OR TRY THIS SCRIPT
Problem solved insert new mmi 3g in other car and go remove protected after install new fw and maps 2019 evritings ok ...I will finish my old mmi and then I will sell it because I could not wait now
Removing battery and reinstalling it 10 seconds later would have solved your issue, bear this is mind next time.
do not be funny, who did not try it ten times this is not the usual radio that this is going to be seriously accessed so I pray that if you are not in the process and you are not a serious programmer you do not give funny comments
This does not work with MMI 3G Hna and Hna +
Worked with radio concert twice. Firmware update screen (due to firmware flash failure) disappeared after disconnecting battery, then after reconnecting I could reflash.
This is something totally different, the mesh of pears and apples
To make it clear, read this
https://dlscrib.com/downloadFile/5a5...b6f5ac5e8c3ca4
