Pls Explain - P0327 Knock Sensor Bank 1
My check engine light went on, this is about 3 weeks after changing a bunch of parts because of some leaks. The code is P0327 Knock Sensor Bank 1 Circuit Low Input. I thought it was connect to the cruise control however, the other day it went on when the cruise control wasn't engaged. Also, it did pop off after a few days, but now it's back again. This is a 2011 3.2L with about 115K miles.
Does anyone know where this sensor is located and if I should really be concerned?
Did anyone have this replaced, how much does it cost?
Thank you.
Thank you.
Thank you.
Thank you.
I would retorque the bolt first, unfortunately it look like a somewhat difficult effort just to get to the bolt, and/or replacing the knock sensor.
Avdwaal1
11
10-08-2013 02:12 PM
BlackS4tt (Josh)
12
11-11-2005 04:29 AM
Hatterasman
06-20-2003 01:56 PM
