Q5 TDI Emissions Fix experiences
#301
Took a round trip today from central New Hampshire to Springfield, MA- about 140 miles each way. Trip computer only indicated 34.0 each way. I’ve done that drive many times and broke 40. The power is fine, it still feels like getting rear ended when you stomp on the throttle, but the MPG is down by more than the 1mpg the booklet stated. I won’t know fully until I’ve tracked a few tanks, but to have the trip computer show that type of disparity...
#302
I wouldn't trust the computer to be all that accurate. I think it's closer now after the fix but it was always optimistic before that. I always calculate mileage and for our 2015 Q5 TDI, that hasn't changed all that much. It's down a little but not by much (probably within the 1 mpg spec).
#303
^^My fuelly calculated mpg’s, reported above, went down 0.6 (so far) after 10 tanks post fix. I always use manual override, after warmup, to stay in lower rpms if available. The ECU and TCU will hold a manual gear for me down to 1100 rpms. Low rpms are a less fuel-efficient for the engine when working, but you save big when you are coasting. Click on my fully badge for more information. YMMV
#304
I think the bottom line in regard to Audi's claimed 1 MPG reduction, is the comparison from pre-fix to post-fix EPA MPG. The high MPG (way above pre-fix EPA sticker) we are experienced was an artifact of the emissions fraud.
#306
Additional thought: it’s the warmup regime that is taking the biggest chunk out of mpg’s. It’s completely possible for many drivers who live in suburbia to do an hour’s worth of errands and never get out of warmup phase. Since I live in the boonies my car is warm and I’m only halfway to town, having stopped at only one sign. Hence, I have almost no decline.
#307
Im seeing about a 2 to 3 mpg reduction. Power is good except I do see the intermittent 'lag' from hammer down until it decides to do something.
#308
Thanks, everyone, for their input to this thread!
I've got a question & an update.
First, does anyone know if an O2 sensor is covered under the extended emissions warranty? I'm thinking that may depend on what the O2 sensor does...sorry for my ignorance on that. If it's post-combustion, I think it would be covered.
Here's an update on our experience after the fix (I posted way back in late JAN/early FEB after getting the fix done):
Vehicle - 2014 Q5 Premium Plus - purchased new and drove off dealer lot on 31 DEC 2013. No after-market chips used, but thinking about that after reading some comments in this thread. (A separate question about transmissions: Are they all the same in the Q5 TDIs? I ask because I've seen some mention paddle shifters, which my vehicle does not have. I can push the shifter over to the right and shift up and down manually, but there're no paddles on the steering wheel in my Q5. So, just wondering if Audi did a transmission switch at some point?)
Emissions fix completed on 24 JAN 2018 at 93,619 miles.
Current mileage is just over 100,000.
We live in a semi-rural, changing to suburban, area, so we've got a lot of flat, straight two-lane roads through farm fields, traffic congestion at certain times of the day and, since we're close to beaches, summer tourist traffic. Fortunately we can avoid most of the congestion. Speed limits tend to be 45 or 50 on many of the two-lane roads, and 55 on the highways. Occasional jaunts to the "big city" will see us on freeways with a 65 limit, but cruising around 80 when possible. So, mostly highway mileage, very little stop-and-go, with some 'suburban' travel mixed in.
Findings:
Overall mileage before the fix was 32.7 mpg, over about 2860 gallons of fuel.
Mileage since the fix is 29.4 mpg, using about 196 gallons. So, it's a drop for sure, but still not bad, IMO, for the vehicle. The new EPA sticker lists 26 mpg combined, 23 city, 30 highway. I think these sticker numbers are each 1 MPG lower than the original EPA numbers.
Problems so far after fix:
1. NOX sensor had to be replaced - covered under warranty.
2. Shift points are higher, even after the engine has warmed up.
3. Occasional hesitation when she's pushed hard from low speed. I've seen this described various different ways in this thread, and maybe even a suggestion of turbo lag (though I may be mistaken about that), but here's an example of what happens: I make a slow (10 mph or less) 90-degree turn from a side road into an acceleration lane for the highway and hit the accelerator to the floor to get up to speed to merge, but the car just sits for a second or less before jumping on it. But that second can sometimes make the difference whether or not I can merge into the break in traffic I was aiming for.
4. This may no longer be an issue, or it may come back again: The engine used to run 'rough'. Not hesitating (except as mentioned in 3), nor missing, just 'rough'...not sure how else to describe it. But, with the warmer weather, that seems to have gone away. She's always been happier, even before the fix, with the warmer weather...just spreads her wings and flies, sipping teeny bits of fuel. So this may come back when summer's over, or maybe not.
5. Now we've got a 'check engine' code of P0133, which is an O2 sensor fault, I believe.
Thanks again for all the info on this thread and elsewhere!
Findings:
#309
Findings:
4. This may longer be an issue, or it may come back again: The engine used to run 'rough'. Not hesitating (except as mentioned in 3), nor missing, just 'rough'...not sure how else to describe it. But, with the warmer weather, that seems to have gone away. She's always been happier, even before the fix, with the warmer weather...just spreads her wings and flies, sipping teeny bits of fuel. So this may come back when summer's over, or maybe not.
Findings:
#310
Findings:
Findings:
