Q5 Transmission Service/Fluid Change
#11
The ATF looked pretty good, said the tech. I chose not to do filter because it added a lot more time and the filter wasn’t cheap. In all I think it was another $200. I am not exactly sure if that was the exact cost but it was something like that. I do not know the procedure, sorry.
#12
this is for drain and fill with new filter, and probably enough ATF left to do another drain/fill, which will replace about 2/3 of the fluid.
https://www.ecstuning.com/b-assemble...t/g060162a2kt/
https://www.ecstuning.com/b-genuine-.../g052145s2kt4/
https://www.ecstuning.com/b-genuine-...e-kit/g0521kt/
#14
Y
Y
did you use the diff kits, I notice they are for the 6 speed version only...
#16
I am about do a full transmission fluid change, to include OEM Filter and gasket. plus replace the fill and drain plug. The reason is because my trans harness o-ring is leaking so I am going to replace the two orings, so I have to drop the pan to do it. Parts are $450 from FCP EURO using OEM parts not OE and Lifeguard 8 fluid (9L). I have a 09(6Spd trans) with 150K.
#17
I got a quote from local Audi dealer in Lex , Ky ( but says it’s a lifetime sealed transmission Reccrmend’s leave it alone.) to drop pan and put in new bolts and oil and filter and gasket , is 2500. Cause it takes a special tool for the transmission,. 1500 just for flush.
I have a 2012 A8L Quattro 4.2 FSI 8 speed auto transmission with Tiptronic
#18
Only I have never had a vehicle I took care of not have this done! Very confusing...
special tool.? The price was ridiculous and I see OEM parts on line much cheaper. But what about special tool.?
