Shifting between D, tiptronic, and S
Is it bad for the transmission to switch between D,S, and tipronic while in motion? I finally reached the 600 mile break in mark and feels good. I am kind of relectant on switching while in motion. I switch modes when I come to a complete stop. Is there any literature on this? I could not find it in the manual.
Works fine although I wish Audi would have put the tiptronic gate next to the sport mode position -- this is bmw's approach. I find that I typically want to use tiptronic when I'm already driving in sport mode. Switching from sport to tiptronic means going through regular drive mode which sometimes results in an up-shift.
shifting on the fly is no probelm, electronic transmission won't let you do it if its bad. i agree the S should be next to the tip tronic gate or if you hit it over. also i would like the tiptronic gate to be to the left. i find the right side is easier to pull back into D if you take a turn and your hand is on the shifter. another gripe not so much is that the +/- be switched. it makes sense how it is but when ur driving due to physics it feels the other way makes sense. oh and one last thing, if when u shifted into tiptronic instead of putting you into the gear your in, if it dropped you a gear or 2 so that you would be in a better gear without downshifting to accelerate.
Paddle shifter
Ok REALLY dumb question, I have a 09 Q5 s-line/prestige - what are you referring to when you say 's' mode. The Q5 does not have a sport mode like my wife's A3 has, or are you just referring to throwing the shifter into manual mode?
John
John
