SQ5 Chrome Exhaust Tips - Corrosion / Carbon Buildup?
#21
Maybe it's the pics, but the OP looks like normal carbon build up on any neglected exhaust tips. Just go after them with Blue Magic and a cotton rag. I've brought dozens of tips that like that back to new. Don't let them get that bad, and it won't take more than a 5 min polish each wash.
The second post looks odd. I wouldn't be confident with those.
However, the stainless steel / chrome plating on the right tail pipe has completely eroded away and shows pitting in the metal (evident on the bottom lip). Not sure what can be done from here...Anyone?
#22
It was a great tip SQ5guyinSoCal. If I clean the tips once week it will definitely just be a spray and wipe. I hadn't clean the tips for about 6 weeks and a little scrubbing with a paper towel did the job. Do you put anything on the tips after you clean them? Thanks again.
#23
Twice a month on the wax? What product do you use? After I bought my Q5 I did a real thorough wash, clayed the vehicle and applied Sonax Polymer Net Shield. The Sonax has held up real good, water still rolls right off and its been about 6 months. The car is garaged however, so that is probably a major reason I haven't had the reapply the sealant yet.
#24
#25
I use Meguiar's Gold Class Carnauba Plus Liquid Wax. What is does to dark colors is amazing. Mirror finish and makes the makes the pearl effect pop. I even wax my 21" wheels (both inside and outside) and the red brake calipers too....keeps the brake dust from building up and just rinse it off with a strong stream of water.
#26
So my first attempt at scrubbing with some Dawn infused soapy water and a non-scratch Scotchbrite pad yielded OK results on the left exhaust tip. I have some more work to do, but the carbon build up is starting to dissolve.
#27
I assume you have to take your wheels off in order to wax the barrel of your rims. I've been thinking about taking my wheels off to do a real thorough cleaning. Been using SONAX Wheel Cleaner Full Effect and a Speed Master Wheel brush to clean the barrels and its been doing a great job, but haven't put any protection on the barrel's of my rims. I'm wondering how the Sonax Full Effect might work on the exhaust tips if I get a carbon build up.
#28
I actually don't take off my wheels when waxing them. With the 21" wheels and their design, I have enough room with my hands to apply the wax on the entire wheel. Also apply a coat of wax to the red brake calipers to keep them protected and makes them easy to rinse off and clean.
#29
#30
