Switched Fuse (Passenger Side)
Old Apr 29, 2014 | 01:02 PM
bombersun's Avatar
Default Switched Fuse (Passenger Side)
Need help looking for a switched fuse on the passenger side. I need to add a cigarette outlet in the glove compartment for a dash cam. I will be using a add a fuse tap. Any help is appreciated!
Old Apr 29, 2014 | 01:28 PM
spijun's Avatar
Tech Guru
Tech Guru
Maybe this will help you
Old Apr 29, 2014 | 02:22 PM
DaveC4S4's Avatar
I've used a Add a fuse tap on both cars, works great, just make sure you secure the ground wire.
Old Apr 29, 2014 | 02:34 PM
bombersun's Avatar
do u remember which fuse you tapped into?
Old Apr 29, 2014 | 03:16 PM
DaveC4S4's Avatar
Don't remember the # but here is a pic. (driver's side)
Old May 15, 2014 | 06:03 PM
bombersun's Avatar
Do you have a recommendation on which one to tap?
Old May 18, 2014 | 02:58 PM
Redd's Avatar
On the black strip, fuse #9 is for the Supplementary Heater, 5A, which most of us do not have.
On the brown strip, #2 is also 5A, for the WiFi that many of us do not have.
So those two fuses should be perfect to tap if you don't have those devices installed.
There's a list of fuses in the manual, but Audi cleverly enumerates them in the reverse order that they are shown in, so they are very easy to confuse.
I'm scouting for places to install an extra lighter socket myself, but may just install some Anderson PowerPoles instead, they take up way less space. Are you planning to just install the whole lighter socket in the glove box? Or is there room to install it "through" the glove box wall?
I stuck a flashlight in the glove box last week and found out, yes Virginia, there really is an air conditioning vent in the back there! In my old friend's '68 Beetle, he had the same thing. Well, a big hole that fresh air blew through from under the hood.(G)
Old May 19, 2014 | 10:01 AM
bombersun's Avatar
Planning on using this with a add a fuse tap.
http://www.amazon.com/Custom-Accessories-10242-Auxiliary-Outlet/dp/B000WEMH4G/ref=sr_1_3?ie=UTF8&qid=1400522449&sr=8-3&keywords=cigarette+socket http://www.amazon.com/Custom-Accessories-10242-Auxiliary-Outlet/dp/B000WEMH4G/ref=sr_1_3?ie=UTF8&qid=1400522449&sr=8-3&keywords=cigarette+socket
<<<@!1!@>>>
Old May 19, 2014 | 11:42 AM
Redd's Avatar
The other option would be to pull power from the overhead panel. If you don't use the remote control functions, you could steal power from right up there (hardwire in) and have less wiring to run around as well.
Personally I like concealed wiring, but I've got no idea how to gently lift an A-pillar cover when there is an explosive charge (the airbag) under it.
Which dashcam are you trying?
Seems like they fall into "cheap, works poorly", "big, invites theft", "expensive for no obvious reason" and a few other categories. Like the one from Cobra, which seems very reasonable until you find out the mount is twice the size of the camera, and the GPS is external-only and a part of the bulky mount, so you can't just do without the huge mount.
Old May 19, 2014 | 03:05 PM
bombersun's Avatar
G1W-C all the wires have been concealed already and ran into the glove box. Just want to keep the cigarette socket on the console free. Thanks for ur help
Khalizzel
Dec 8, 2017 01:45 PM
chachachachia
Audi A3 / S3 / RS 3 MKII
Jan 6, 2017 10:18 AM
swz
Aug 14, 2007 07:31 PM
05A4
Aug 31, 2004 08:01 PM
