Tank Fuel Pump
Tank Fuel Pump
Hey all,
My fuel pump filter on my 2009 Q5 was cracked and leaking so I'm replacing the filter. My question is very specific. After reinstalling everything, my car wouldn't start and I got a tank error in the display. Digging back in there, I pulled everything out and noticed this line with the tank end loose. I know it belongs down in the tank but, reaching down there, I can't feel a fitting for it, so I don't know if there's one I'm missing or if this line is just supposed to hang open in the fuel. It's the long yellowish line in the picture. Any insight is greatly appreciated.
long yellow line
long yellow line
I think you have air in your fuel system. You may need to bleed the fuel system. I am attaching the fuel system manual for diesel. If you need gasoline manual, someone else can provide.
That is called the suction jet pump, that's attached to the fuel delivery unit.
The manual states that the suction pump should be pulled slightly upward, remove from fuel delivery unit, (leaving it in the tank?), them remove the fuel delivery unit.
I sure hope for you that the other end of the suction pump hose must not be attached to something in the tank, that would be the worse nightmare!
No other diagrams in the service manual shows where the other end of the suction pump hose goes.........
Good luck!!!!!
Good luck!!!!!
I'd suggest a cheap waterproof borescope to take a look inside the tank and see if anything really is there for the other end. If there's nothing in sight, perhaps (despite the name) this is a fuel *return* hose of some kind? And it is just dropping excess fuel back in the far corner of the tank?
Best thing to do is contact a tech at an Audi dealership, and maybe hewould tell you if the hose other end does connect to something, or just hangs down in the tank.
Seeing that the service manual tells you to disconnect the suction pump with that hose from the main fuel delivery unit and just let is lay in the opening sort of suggests that the other end of the hose is attached to something in the tank, otherwise the pump and hose would fall to the bottom of the tank.
But who knows.........
I'm with you on that, Bob. But if it is waterproof, it should be reliably vaporproof for one use. And there's nothing really "sparky" in them. If it isn't flickering and blinking...it should be a solid circuit, and reasonably safe. Of course, you would also only be using brass or bronze tools around a fuel tank anyway, yes?(G)
I would add...... Use at Your Own Risk................
