VAG-COM codes
#361
#362
Ok, thanks for that. When I looked that function the owner manual read it was for oil change only. I could be wrong, so I will try it when I do the 15000 mile service. I was just asking if anyone had direct knowledge of the 15000 mile service reset. There must be a few owners that do their own service. I was hoping to tap into their experience in this matter.
#363
#365
in the green menu:
car -> carbussasignment -> Interior light - change setting to "[CAN Komfort] 1/9"
#366
FYI, for my 2014 SQ5, there was one additional step required to activate the menu (it was grayed out even after doing the VAG-COM changes and the green menu changes noted in the thread earlier:
in the green menu:
in the green menu:
I was wondering if someone who reads this post and knows how to achieve this (display the hidden menu) with a RossTech cable? Is this possible at all? I do not own the VAG cable.
Advice is very, very much appretiated. Thank you very much in advance.
#367
Probably there is only the mmi reset When I tried I did not succeed.
The service reset probably it has to be done online with their diagnostic. The mmi reset is what I am using. If you wish you can vary this to 7500km or 15000km. or 10000km with vcds.
So I only use the reset button since it is perfect as a reminder. You do t really need the service reset.
#369
