Water/condensation Tailgate light housing
Anyone know how to get this light housing off? I’ve got some water or condensation buildup inside the light housing. From what I can tell I’m going to have to remove the black trim piece on the inside but I don’t want to break anything… This is a 2016 SQ5 CPO still under warranty so I don’t know if I should do this or just take it to the dealer. Any advice?
Yes absolutely go to the dealer.Removing the rear hatch inner cover isn't rocket science but there's a lot of potential for breaking stuff so let Audi deal with it.
"This is a 2016 SQ5 CPO still under warranty "
Yup. 100% let the dealer handle it. resealing lights can mean playing "whack a mole". New light assemblies can be rent money. And, if there's water in the lamp assembly, the wiring subharness can be rotting out from it--a REALLY proper repair would also involve checking for that.
VWG had a really bizarre issue with "fluid" in some tail lights maybe five years ago It turned out that COOLANT was leaking past a temperature sensor, on the engine, and then flowing downhill inside a primary wiring harness until it pooled up IN THE TAIL LIGHTS.
Bizarre, but true. So, might as well get the problem documented and dealt with under warranty.
Ok thanks everyone. I’ll make an appointment for it next week. I thought i had read somewhere where Audi may not do anything about and would claim it was normal.
Manwich "Audi may not do anything about and would claim it was normal." that's more likely to come from a dealer and if it does, move on.This is NOT normal.Left rear tailight will eventually fail due to moisture infiltration.That is a safety issue.Audi must address it.
Manwich-
Some dealers may not want to bother with warranty jobs because (rashly assuming Audi is like everyone else) the factory often pays less than book price for warranty work. So a busy dealer might rather pass on it. But, any dealer with basic business skills (that lets out many of them) will be eager to submit a warranty job. It makes customers happy and keep the shop busy, and should up their profits. If your local dealer is an Audi Magna Society (?) member, that's an aware AoA gives out to the dealerships that have gotten the fewest complaints, or most praise (G), from customers. Usually means a shop that is better at getting anything "questionable" done by warranty.
Last week I took someone's non-Audi in to their dealer for an oil change. Couldn't figure out why it was taking so long. It turns out, the service advisor apologized, their standard service check includes a battery load test (!) and they had replaced the three year old battery, under warranty, without even being asked. Sounds like their shop has found a way to make money on "warranty work" but...hard to argue with a free new battery from the battery fairy.(G)
No $200 battery re-programming charge or diagnostics needed, either.
Sometimes, the dealers go the extra mile. They know it means more long-term business.
Condensation in Rear Tail Lights
