2014 Q5 TDI ticking/grinding noise
Bought a 2014 tdi. It started making this noise. We changed the axels and exhaust hanger. Used a stethoscope while driving it on jack stands and it doesn't appear to be coming from differentials or wheel bearing. The noise is only present while driving and not idling. It's intermittent and only happens about 5 minutes into driving as the car warms up. The vibrations can be felt through the floor and in the brake Pedal. Here is a link to the video
https://vimeo.com/764367180.
Any insight you may have would be much appreciated !
This section is for the 2018 and up.
You should go here:
https://www.audiworld.com/forums/q5-...iscussion-129/
That covers your model year
Hope you fix your issue
You should go here:
