Audi Q5 2019 Reverse mirror tilt
Hello, I have an Audi Q5 2019 and I noticed that the mirror tilts when reversing.
However, I think the mirror should tilt down rather than up (it tilts up rather than down right now).
How do I change this and how do u turn on/off mirror tilting?
Make sure the mirror adjustment **** is set to the right mirror, Then put the car in reverse so the mirror tilts (up in your case), while keeping the car in reverse use the mirror adjustment to set it to the position you want it to go into while in reverse. Put the car back in drive and move forward 100 feet and the mirror will tilt back to the normal driving position.(Mirror only tilts back to normal when you actually move forward.
Note the mirror adjustment must be set to the right mirror for the tilt function to work. If the mirror adjustment is set to the middle or left position then the mirror will not tilt while in reverse
