Q5/SQ5 MKII Discussion Discussion forum for the Second Generation Audi Q5 SUV
Light vibration on acceleration
Old Jul 3, 2021 | 05:18 AM
  #11
rolas27's Avatar
Did anyone figured what this could be? I’m having the same issue on my 2017 a6.
Old Aug 23, 2022 | 08:36 PM
  #12
rAi_'s Avatar
I'm experiencing this on a 2019 Q5. I feel a vibration in the engine and slightly through the steering wheel at parking lot cruising speeds all the way up to highway speeds. It happens when the engine is between 1250 - 1750 RPMs and accelerating. A similar 2018 Q5 I test drove last week did not do this.
I will try the different drive modes as others suggest to see if I can spot a difference.
Old Oct 18, 2022 | 11:04 AM
  #13
Wantboost's Avatar
having a vibration issue also I can feel in the steering wheel and even in the gas pedal I'm trying to notice if it's between first or second or from 0 to 1st it's only under light acceleration and I'll start taking note of the RPM. So this is supposed to be normal cause of no trique converter
Old Oct 18, 2022 | 11:53 AM
  #14
sQ5Atlanta's Avatar
If a vehicle has automatic transmission it has to have a torque converter. Unless it has an electronic clutch. IMHO
Old Oct 18, 2022 | 11:57 AM
  #15
Wantboost's Avatar
I dunno its dsg
Old Oct 18, 2022 | 09:42 PM
  #16
slow8p's Avatar
I've been experiencing this problem too. Mostly present upon acceleration and deceleration while at highway speeds (65-75) on front right passenger side. Not sure if worn wheel bearing on passenger side or like previously mentioned out of balance CV axle in the front. Currently at 66k mi.
Old Oct 19, 2022 | 06:14 AM
  #17
rAi_'s Avatar
I tried the different drive modes and it makes no difference. The vibration persists.
My dealership has been awesome and they are helping diagnose the issue. They found a leaky engine mount, and this turned out to be a good candidate theory (search it up). Unfortunately, after replacing it, the vibration persists. Maybe there is another leaky engine mount.
Old Dec 20, 2022 | 05:34 PM
  #18
chassis's Avatar
9Y0 Cayenne owner here stopping by from Rennlist.
Are there any new updates on this? Panamera and Cayenne have 60mph vibration and after much diagnosis it seems the leading candidate is the center wet multiplate torque coupling, aka quattro Ultra.
Attached Thumbnails Light vibration on acceleration-screenshot-2022-12-20-9.29.47-pm.png
Old Jan 7, 2023 | 10:07 AM
  #19
rAi_'s Avatar
Thanks for sharing this.
On my end, we replaced a leaky engine mount but that did not fix the issue.
Vibrations are still noticeable at various drive speeds, when the engine is running between 1000 and 2000 RPMs and I apply light throttle.
There are no vibrations when the car is in neutral, which suggest (to me) that it is a an issue with the transmission.
Do you have any more insights into why this part is causing the vibrations and how to diagnose it? Is this a known issue? Any pointers to tech reports that I/we could take back to Audi?
Old Jan 14, 2023 | 09:40 PM
  #20
rAi_'s Avatar
This is the link to the referred post. Lots of great info there. https://rennlist.com/forums/cayenne-...bration-9.html
